What gear ratio should use on XXX-T Matt Francis 1 ? -
03.24.2005, 09:13 AM
Hello,
what gear ratio I should use when I will have my brushless combo ? (MGM Compro 80amp with Feigao 8s) I will use it with 6 cells and sometimes 12 cells and in the future 3s 11.1 LiPo. My gear ratio of my brush setup is 22/86.
I usually recomend gearing the 8s similar to a 12 turn motor for the applicable vehicle (starting point). If you go to the 11.1 volt LiPo setup, I would drop a tooth or so as a starting point. You can adjust from here, but this should put you in a safe starting range.
