Brushless LST Conversion - Looking for Motor Suggestions.
hunter306
hunter306's Avatar
Brushless LST Conversion - Looking for Motor Suggestions. - 07.18.2006, 05:59 PM
I have done one conversion thus far, my Brushless Losi LST.
It currently runs with a 2 speed emaxx transmission and the Novak HV-Maxx brushless setup. While the Novak setup seems to work ok *haven't had any trouble with thermaling on 12 cells* i'd like something that will feel closer the the speed and power of my Nitro engine.
I'm looking to get the BK Warrior 120amp speed control... But I want a good motor that will carry a fairly heavy - about 13.5lbs - 4wd truck.
Any suggestions for under 300 bux? How about over 300?
For anyone interested, pics of the conversion are in hi-res on my website:
http://www.deependstudios.com/rc.html
coolhandcountry
coolhandcountry's Avatar
07.18.2006, 06:27 PM
There is alot of options. If you mounted a 2240 on it. You would have great power and speed. The 1950 would be a good motor as well. But all of them are over 300 by there self. I would run a xl motor at least. If you run lipo 6s would be great on a 10xl.
Welcom to the forum to.
Peace!
Country
Help support the
Rc-Monster
Buy here
hunter306
hunter306's Avatar
07.18.2006, 08:58 PM
Good deal, Now a question for you... Is the BK Electronics 12020 - 120amp control going to be a sufficient setup for about 14-16 cells and the 1950 size lehner motor?
Do you have a good suggestion for a Brushless Control that might be capable and cheaper?
coolhandcountry
07.18.2006, 10:33 PM
The 120 20 would do. I would go 1950 7turn for the cell count you stated. The 9920 should work but the 12020 has a little insurance level.
Peace!
Country
Help support the
Rc-Monster
Buy here
squeeforever
squeeforever's Avatar
07.19.2006, 12:17 AM
I would go for a Quark 125 instead.
aqwut
Brushless Heavy Weight....
aqwut's Avatar
07.23.2006, 10:43 AM
I'm running Fieago 7XL on mine. Using BK9920 with fan. and 12 to 18 cells IB4200.. no problems at all. I can run pack after pack.
neweuser
neweuser's Avatar
07.23.2006, 11:14 AM
Aqwut, with the 7xl, more than 12 cells and you don't have heat issues? Pack after pack?
sjcrss
Hyper 7 Erevo Center Diff
sjcrss's Avatar
07.23.2006, 11:27 AM
I've been running the following sytem in my maxx for quite some time......here is what I recommend.....I'm sure others will say nay...but it's been very reliable and dependable for me
1920/8 lehner
2095 Micro BEC controller
on 12 cells, but I have gone up as high as 16 cells with no issue....and my maxx at one time weighed in at 13 lbs....
you could allways go with the 20120 Micro..... and a 1920/7....that would be the lowest I would recommend...but my 1920/8 has never let me down....let alone with any heat issues.
neweuser
neweuser's Avatar
07.23.2006, 01:28 PM
1950/7 with the 12020 or quark would be a nice set up. You would have some room to play too.
hunter306
hunter306's Avatar
07.23.2006, 01:56 PM
I like the 1950, but it may be to pricey for me to get it... On the other hand, I guess if I'm gonna build this thing, I should just get a motor that will be a good fit.
Are the Wanderer XL series motors any good? I looked in the store and they are a bit more affordable... Anyone have one of these?
squeeforever
07.23.2006, 02:14 PM
I run one and love it. Kinda wish I woulda bought one of them to begin with instead of the Basic XL and then Feigao XL though....You would be plenty happy with a XL but a 1950 would be the best choice.
hunter306
hunter306's Avatar
07.23.2006, 03:04 PM
Is the Wanderer XL a long can motor.. I don't see any dimensions, can you let me know about the size of the Wanderer?
squeeforever
07.23.2006, 05:08 PM
I believe there about 76mm long. The XL indicates the length. They go from S to L to XL.
hunter306
hunter306's Avatar
07.23.2006, 05:48 PM
Thanks alot. I think that I'm going to try the Wanderer... It's close to what I'm looking for and I can always upgrade in the future.
squeeforever
07.23.2006, 06:01 PM
If I were you, I would get the Feigao C XL. There indentical internally, but the Feigao is a sealed can design with the built in heat sink.
