New To The Brushless Family
Puttinstankonia
New To The Brushless Family - 07.23.2006, 12:16 AM
Hello,
I am new to the Brushless/ LiPo Game and i was wondering what i should be running in my 1/10 scale tourer.... All i want is speed and im looking for a nice set up... Can someone please help me? I would like to know what total set up i could run for under 400... to give me what i need...
nieles
nieles's Avatar
07.23.2006, 05:10 AM
this is a nice motor and esc for 1:10: castle creations mamba max
http://www.castlecreations.com/products/mamba_max.html
  Send a message via MSN to nieles
Puttinstankonia
07.23.2006, 10:57 PM
Thanks but is there anything else out there too so i can weigh my options
07.23.2006, 11:23 PM
Yes, there are more options, but pretty much anything equivalent you piece together will cost more. The Mamba Max aside; from opinions around here, the Quark or MGM are the high-end ESCs with the BK Warriors being middle of the road. The more expensive ones will generally have more programming options. For motors, the LMT 1920/1930/1940/1950 are the cream of the crop, followed by the Lehner Basics/XLs, followed by the BK Wanderers.
First figure out your budget. Then, figure out how many cells (and what kind) you want to use. BL motors seem to be most efficient in the 35-40k rpm range, so you use that to figure out what kv motor you need. The size and weight of your vehicle will determine how big (how much torque) your motor will need to be. Given your various drivetrain reduction (tranny, diffs, spur/pinion, etc), you can figure out your approximate speed.
Puttinstankonia
07.24.2006, 12:33 AM
Well i was trying to figure out how to get a high powered saddle pack because since im limited to the saddle pack set up i only have so much space to work with.... all i found was MaxAmps Lipoly 5500mah 7.4V Saddle Pack and i have a budget of about 450...
