Pushing brushless to the max
Hayden
Pushing brushless to the max - 07.26.2006, 09:44 AM
I have not seen a maximum volt or rpm rating on a brushless motor yet, there will be a limit so what is it? Before it flies or burns to pieces:035:
BP-Revo
BMW M Power!
BP-Revo's Avatar
07.26.2006, 10:17 AM
Generally you want to stay around 40000.
Over that you risk blowing the bearings. Theres other stuff too, but I dont remember.
squeeforever
squeeforever's Avatar
07.26.2006, 10:44 AM
You could have the magnet come off the rotor, fry the windings, etc. Stay around 35 to 40k. It will run cooler, more efficient, etc.
07.26.2006, 10:51 AM
So, based on the previous posts; find the voltage to use by simply dividing the max rpm (35 to 40k) by the kv value of the motor.
Using 35k rpm as the max rpm:
For a motor with a kv of 2000 rpm/v, you'd want to use 17.5v.
For a motor with a kv of 1000 rpm/v, you'd want to use 35v.
Motors with lower kv values will have more windings, therefore will require less current. However, since you are using higher voltage with less current, the total power will be roughly the same as a motor using lower voltage but higher current.
squeeforever
07.26.2006, 11:42 AM
To add to what Brian said, a higher voltage setup will usually have more runtime as well because the motor will pull less amps. It would also be easier on your ESC.
MetalMan
MetalMan's Avatar
07.26.2006, 02:04 PM
But that's only if you gear down. If you don't change gearing after switching to a higher voltage setup, your runtime will be less (assuming same battery capacity) and it will be harder on the ESC and motor.
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
07.26.2006, 08:06 PM
I think he's talking about a high voltage setup that also uses a slower motor. In that case you will definately get more runtime.
Area 52 Ranch Raceway
T.R.C.R.
squeeforever
07.26.2006, 09:26 PM
Yea, I meant if you use a lower kv motor.
hunter306
hunter306's Avatar
07.26.2006, 09:41 PM
65.000 u/min --- I see ratings like these on a lot of the motors... is that a rpm rating or is that something else. Please correct me so I am more knowledgeable.
coolhandcountry
coolhandcountry's Avatar
07.26.2006, 09:44 PM
That is the rating for like the balancing and bearing rating. It is not good to push it that hard. I have pushed some pretty hard with out destruction. You can push more than 40k rpm but just not continously.
Peace!
Country
Help support the
Rc-Monster
Buy here
hunter306
hunter306's Avatar
07.26.2006, 09:50 PM
Thanks CHC, that's what I figured.. I noticed everyone was saying to hover around 40k continuous RPM to make sure you don't have a premature failure of the motor.
I've got couple brushless motors on there way for use with my new Quark 125... should be interesting.
Hayden
07.27.2006, 06:14 AM
I see motors with 6500kv that they put small 4 cell lipo in shockflyers, helicopters etc
There must be a limit for warranty issues
SpEEdyBL
SpEEdyBL's Avatar
07.27.2006, 05:59 PM
Smaller motors have higher rpm limits of course.
T.R.C.R.
squeeforever
07.27.2006, 06:08 PM
Probably because the RPM's will drop drastically under load, correct?
SpEEdyBL
SpEEdyBL's Avatar
07.27.2006, 06:10 PM
They have less rotor mass so they're less likely to explode.
T.R.C.R.
