Quark 125 & Lehner 1950/8
danverz
Thumbs up Quark 125 & Lehner 1950/8 - 07.28.2006, 09:05 AM
Hi Guys,
I just want to make you know how this configuration rocks.
I'm really near to finish my S-G Maxx and I'm using it as a 2WD Truck
(missing front center bone) while waiting for my order.
It has a strobe slipper with an ofna mod 1 51 spur and a 15 pinion,
it has a single speed trasmission from Gorilla/fastlane,
it has an UE 7.5 8 spider diff
it has (by now) road rage tires (40)
it's 5.2/3 Kilos of weight with batteries and body
and finally the beast:
a lehner 1950/8 with a Quark Monster 125B with two pack in parallel of
flight power EVO20 5S 3700 lipos.
It's a BEAST ..... Really impressive I must take a video ...
I reached 54C° for the motor and 53C° for the controller with the
softest setup for lipo and with the manual cutoff at 3V per cell (ambient
temperature = 30C° ... very hot).
Over 1880 watts, 97 Ampere, 35 minutes of bashing on the road and on
a dirty yard and stopped due to a servo arm problem.
When I went to charge the batteries, they were at 19.4 volts !!!!!!!!!!!!!!!!!!!!
Only about 1800 mah per battery of charge.
I think I'll be able to bash for over an hour !!!! Impressive !
The controller is refreshed from 2 fan and 2 heat sink. And it lies on the
alluminium with some silicon paste (the one you use for the PC cpu).
The motor has a fan under pushing air, and it will have other 2 fans on
the heat sink for the motor pulling the air to the sky. So I will have a
general airflow from the bottom of the model to the sky. I will also cut
the body on the top of it to make air coming out.
Here you'll find some photos of the story of the truck:
http://chroot.penguin.it/gallery2/ma...g2_itemId=1373
GO BRUSHLESSSSS !!!!!!!!
Ciao,
Daniele
neweuser
neweuser's Avatar
07.28.2006, 09:34 AM
Looks good. One question though. Why Road Rages? Bow ties or Crime Fighters may have been better for bashin...IMO. Anyway, very nice! Would like more pics of the fan and motor set up! : )
danverz
07.28.2006, 09:41 AM
You are surelly right. I just received a pack with inside 4 crime fighter 40
tires with velocity wheel with 23mm hex. And the motor fans/heatsinks.
That Road Rage tires were the first I had: I had them from a very great friend
of this forum. Anyway I was able to reach over 1880 watts only on the road,
not in dirty bashing, due to the better grip :)
Ciao !
Daniele
neweuser
neweuser's Avatar
07.28.2006, 10:07 AM
I run the crime fighters and love'em! great all around too. Waer fast oin pavement, so try to stay off that as much as possible, can be done, but hard on the tire. You'll really like the crime fighters! can't wait to see your final project!
danverz
07.28.2006, 10:20 AM
I'm waiting some stuff from Mike, at this point I hope to hear him
on monday.
With a 2WD bashing is pretty uncontrollable.
I was wondering if with the 40 tires I would do better buying the gorilla
extension of the chassis.
BTW other photos within some hours :)
Ciao !
Daniele
neweuser
neweuser's Avatar
07.28.2006, 10:29 AM
I run the extension and like it a lot. U can use an mip center shaft like i do for the front. I have the bone to put in, but haven't becasue the MIP has held up so far and i won't replace it until I break it! I run the extended steel from Mike for the rear.
coolhandcountry
coolhandcountry's Avatar
07.28.2006, 10:33 AM
I like that 1950 8t myself. I run mine on a 6s system. It is great.
I average about 30 mins with a 3800 pack so you should be able to hit an hour with 7400 mah. Can't wait for pics.
Peace!
Country
Help support the
Rc-Monster
Buy here
Dafni
Dafni's Avatar
07.28.2006, 11:48 AM
The very same setup (batts and all, to the point) that I have lying here to put on a current project! :) Looking forward!
Cheers
DAF
danverz
07.28.2006, 11:50 AM
Cheers
DAF
Dafni you probably already have seen that racerx arms, that shocks, and so on :)
Serum sold me that !
Ciao :)
Daniele
standard_63
standard_63's Avatar
07.28.2006, 12:31 PM
How is it that the 3700s are enough for 97A draw? Is it that they are wired in parallel?
I have a 7XL Wanderer that gets pretty hot, would the 1950/8 run significantly cooler due to efficiency? My 9920 and batteries are pretty cool, but if I gear up at all they get hot. Present gearing only motor gets hot after 18 minutes -- 183f!!
Please tell me that's not smoke I see!
neweuser
neweuser's Avatar
07.28.2006, 12:37 PM
The lehner should run significantly cooler due to efficiency yes, gearing makes big difference in that though too, gearing is touch and go, try a few up and down and see how she does...IMO 183F is toooo hot!
standard_63
07.28.2006, 12:50 PM
Yeah, I tried up and down. Down 1T and motor gets even hotter. Up 1T and ESC and motor get to 160f and it shuts down after 5 minutes. At 14T with UE diffs and the big mashers it goes for 8 minutes or so before thermaling, then will run another 8 or so before the batteries dump.
I have a fan on the esc, but only a heatsink on the motor. I need a fan on there too, but need to hook up a mount. Maybe Mike could make an integral motor heatsink/fan mount thingy.
My tires might just be too heavy also, this weekend maybe I'll try a lighter setup...
Dafni
Dafni's Avatar
07.28.2006, 12:51 PM
standard_63, this battery setup gives you 20C continuous, which results in 148amp! (and 222amp peak) Should be enough, eh? And yes, Daniele said 2 in parallel.
Cheers Daniele, so the stuff stays in the family! Nice to hear Renes parts found a good home. Keep it up!
coolhandcountry
07.28.2006, 04:55 PM
How many cells there standard?
Peace!
Country
Help support the
Rc-Monster
Buy here
danverz
07.28.2006, 05:59 PM
Speaking about nominal data, we are about 16 cells nimh.
But I see my lipos, nominal 18.5 volts, stay without trouble between
21 and 19 volts for at least hald of the charge. This make them very
near to 18 nimh cells.
Some other photos of my truck in a short time :)
Daniele
