OPTO mod for quark
tallyram
tallyram's Avatar
OPTO mod for quark - 07.29.2006, 07:00 PM
i'm assuming that all it requires is wiring in my ubec. i want to make sure so it won't be going back to the manufacturer like my bk! thanks, tally.
  Send a message via AIM to tallyram
07.29.2006, 08:24 PM
Are you asking how to wire up a ubec to the Quark and disable the ESC BEC?
tallyram
tallyram's Avatar
07.29.2006, 08:29 PM
yes. the way the instructions word it makes it seem like you just wire in the ubec, and that disables the esc bec. help!
cemetery gates
07.29.2006, 08:40 PM
to disable the bec pull out the red wire in the reciever wire on the quark. thats all you have to do if i remeber correctly...
coolhandcountry
coolhandcountry's Avatar
07.29.2006, 08:58 PM
You right cemetry gates. That is the only way I know of with out going in.
Don't worry tally. If you send it back it is alot faster than bk. 2 weeks I had another one and rolling.
Peace!
Country
Help support the
Rc-Monster
Buy here
tallyram
tallyram's Avatar
07.30.2006, 02:52 AM
so just pull the red receiver wire out of the receiver plug and snip it off, done? should i snip it off all the way against the esc body?
MetalMan
MetalMan's Avatar
07.30.2006, 11:32 AM
You don't need to remove the red wire. You can just tape it (still intact) to the other wires it's next to. That way if you ever use 6-10 cells, you can use the BEC.
neweuser
neweuser's Avatar
07.30.2006, 01:16 PM
I just unclipped it from the connector and heat shrunk it up a ways...
07.30.2006, 02:20 PM
That's what I did too...
