E-ReVVo/SoldierMaxx
FLM Extended EMaxx Center driveshaft -
08.01.2006, 05:21 PM
All,
I haven't seen any posts that wonder why the FLM Extended EMaxx chassis only comes with one center driveshaft. Is the idea to just keep the stock shaft on the back and use the extended driveshaft dogbone in the front? Seems like it should come with two dog bones and cups unless the assumption is that folks have already installed a stock-length center driveshaft kit for front and rear. If that is the case, then one would only need a new dogbone to cover the extra chassis length???
As for me, I bought CVDs for the front and rear wheels, but not for the center because I thought it came with the FLM Extended chassis kit.... but I'm just an OldSoldier...what do I know. :032:
08.01.2006, 06:56 PM
The one that comes with the chassis is for the rear. The rear takes alot of the punishment and most have upgraded to.
welcome to the forums
Peace!
Country
Help support the
Rc-Monster
Buy here
E-ReVVo/SoldierMaxx
Center drive shaft/dogbones -
08.02.2006, 11:01 AM
Thanks for the reply...but let me change the question just a bit:
What should I order to upgrade the front-center drive shaft given that I'm about to install the FLM Extended chassis and the Feigo 9L Brushless motor with Quark 80 Brushless controller??
08.02.2006, 11:28 AM
You will need a 70 mm shaft or dogbone with drive cups. If you email mike he can hook you up with the right ones.
Peace!
Country
Help support the
Rc-Monster
Buy here
Breaker of all that is Stock
08.03.2006, 05:19 PM
You are most likely going to have thermal issues with the quark 80 its a bit small for your application. Even the 125's have thermal issues unless they are run with heatsinks and or fans.
Never fight an ugly man..... he has nothing to loose
E-ReVVo/SoldierMaxx
08.03.2006, 11:23 PM
Thanks for the advice guys... Guess I should have spent the extra money and gotten the Quark 125 and the Feigao 9XL. Well, too late now. I'll have to make do. So far, I added a heat sink to the Feigao motor (went cheap with the standard Traxxas $5 heat sink).
I also took Sqee's advice and changed the gearing to 16/66. I Definitely see a difference with less heat in the motor and less heat on the speed control. :027: BUT the insane speed I was getting with the 18/66 gearing is also gone :019:
Its still better than the original twin titans, and MUCH longer run times using a pair of 7.4V 6000mAH batteries.:018:
08.04.2006, 06:20 AM
Sounds like an all around winner - much more run time - less heat - Good to hear...
Hows that "Hope and Change" working out for Ya???
08.14.2006, 08:30 PM
I use the UE Supermaxx Ti 105mm shaft on the back and I believe its a 70mm on the front with my FLM chassis. They are the best ones made.
08.14.2006, 08:55 PM
I used the 100.5 mm shaft for rear. The 105 was for the lightning and flm chassis. The 70 mm works for front.
Peace!
Country
Help support the
Rc-Monster
Buy here
E-ReVVo/SoldierMaxx
08.22.2006, 05:58 PM
Thanks for all the replies guys. I just finished rebuilding my E-Maxx into SoldierMaxx with the FLM chassis. I used the standard Traxxas u-joint style drive shaft in the front and the one that comes with the FLM chassis on the rear. I haven't done any testing on the track yet, but it's doing well on the street and in the grass.. I'll post a few pics when I get a chance.
I made a mistake when I said my gearing was 18/66 above...it was actually 18/72 (I thought I had a 66-tooth spur gear...turned out when I disassembled the truck that it was a 72-tooth gear.
I'm now testing (emphasis on the word test) with motor/speed-control unfriendly setup of 20/66 just to see how far I can push the Feigo 9L and the Quark 80B Speed control. I'm running topless for now since I'm just testing and I have not painted my new Hummer body for it yet. Running topless should help protect against overheating for now. :013:
09.28.2006, 10:27 AM
Old Soldier,
Any updates on the FLM E-Maxx? Pics maybe????
09.28.2006, 12:31 PM
a few pics to enlight the forum perhaps.. :)
09.28.2006, 12:46 PM
Exactly! We're a picture hungry bunch!
09.28.2006, 12:49 PM
don't forget to mention him about our indomitable lust for vids !!
09.28.2006, 01:06 PM
Well said Serum!
:027:
NEED MORE VIDEO'S.......NEED MORE VIDEO's......:004:
