Originally Posted by BrianG
And it's not advisable to run NiMH/NiCD in parallel. Only Li seems to be acceptable for parallel running AFAIK.
I am curious as to why you say this. The weight and area the batts take up is the main reason why like rene stated. To get twice the capacity you have to add 12 cells to a 12 cell system for 24 cells total. That is alot of weight. If you go that route just get lower kv motor and run in series for it would be more efficent.
