9918 Installation Question
Qball76
9918 Installation Question - 03.27.2005, 12:15 PM
I've got everything installed on my truck now and I'm getting ready to install the controller, motor, and ubec. Where on the controller is the jumper located that needs to be removed in order to run the ubec externally? I cut the shrink wrap off near the red positive battery lead but I don't see anything.
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
03.27.2005, 12:40 PM
It is near the red programming jumper, under the heat shrink. It is a black "tab" that you simply pull out. It is just below the caps.
Qball76
03.27.2005, 12:43 PM
Is the small black tab connected to the actual circuit board?
Qball76
03.27.2005, 12:44 PM
Nevermind, I'm assuming it's the black tab that I just slid off of the two prongs.
Qball76
03.27.2005, 12:46 PM
Sorry for all the questions Mike, but does the UBEC plug end go over the prongs that I just removed the tab from?
RC-Monster Mike
Site Owner
03.27.2005, 12:51 PM
The plug on the UBEC plug goes into the receiver. The wires get soldered directly to the battery connections.
Qball76
03.27.2005, 01:43 PM
Do I need to remove any wires from the plug going to the receiver since I'm using the UBEC, or do I just plug it in like it is since I removed the black tab already.
RC-Monster Mike
Site Owner
03.27.2005, 03:24 PM
Plug and play. No need to remove any of the wires. Removing the BEC jumper is all you need to do.
