Setup Advice
Puttinstankonia
Setup Advice - 08.16.2006, 09:14 AM
Can someone give me an opinion on this setup and let me know if it will give me the speed i am looking for
1/10 scale tourer
- 22.2 Volts LiPo
-1920 Lehner
- Phoenix 45-HV
-Low Voltage Cut off
Along with the opinion on the setup can someone tell me what else i might need? (what Pinion etc)
GeeReg
GeeReg's Avatar
08.16.2006, 12:17 PM
6s in a touring car? I would think you would get diminishing returns due to weight with 6s but I don't necessarily know what I'm talking about.
RC10T2 - Novak SS5800 - 7-cell GP3700
HPI RS4 Nitro MT - Mamba Max 5700 - 2S 5500mah Lipo
MRC Thunder King - Mtroniks Truck ESC + Feigao 9L - 3S 6000mah Lipo
Serum
Serum's Avatar
08.16.2006, 12:20 PM
Why do you want to use that castle controller? for 6S it's kind of weak for the 1920. a better option is to get a real car-controller.
Phoenix-45HV
Puttinstankonia
Phoenix-45HV - 08.16.2006, 01:29 PM
What controller do u suggest for this setup then and the pacs that i found for the tourer are lighter than the 10 cell NiCd's i had in there with a 6 turn orion a couple months ago... The HV is said to be able to handle 50 Volts.... please help then
Serum
Serum's Avatar
08.16.2006, 01:33 PM
That controller is meant for planes, it has got no proportional brake and it is made for stick transmitters. what is your plan? speedrecord?
Puttinstankonia
08.16.2006, 05:48 PM
No speed record but i do want a lot of speed.... So i was trying to figure out a good set up im basically going to drag my car... What controller do u recommend that can take 22.2 volts and still give the power desired to run the 1920...
squeeforever
squeeforever's Avatar
08.16.2006, 06:05 PM
A 9920 or a Quark 80 would be my choice.
Serum
Serum's Avatar
Quark 125 or the 80
22.2V in a 1/10th is insane.
11.1V is untamable power allready, so imagine 22.2.
What experience do you have with brushless in cars?
Puttinstankonia
08.16.2006, 06:09 PM
Thank yoiu very much the Quark 80 it will be then
I think i might have to run foams on there too
Puttinstankonia
08.17.2006, 01:08 AM
Is everyone sure that the Quark 80 can handle 22 volts because in checking online i dont see where it says that it can... Can someone get back to me on that?
08.17.2006, 01:24 AM
It is supposed to take up to 6s or 18 NiXX cells. Look at the product description on this site.
tallyram
tallyram's Avatar
08.17.2006, 02:55 AM
i wouldn't bet on it handling 6s. 4s is as high as i would go. i'm speaking from experience! i own a 125b, almost identical!
  Send a message via AIM to tallyram
Serum
Serum's Avatar
08.17.2006, 12:30 PM
Daniel runs his with great succes on 5S, i thought this 6S thing was an issue, but mike had a conversation about this with the distributor or something. I thought it was addressed.
coolhandcountry
coolhandcountry's Avatar
08.17.2006, 12:57 PM
It is not addressed in my quark rene. I still can't run 6s with out the start up problem. I going back to a 4s packs. 7020 bk is an option. I would not run the 45 for the motor will draw more amps than the controller is rated for.
Peace!
Country
Help support the
Rc-Monster
Buy here
Serum
Serum's Avatar
08.17.2006, 01:03 PM
you can do 5S with ease on the quark though,
