Someone double check this quickly please
GeeReg
GeeReg's Avatar
Someone double check this quickly please - 08.31.2006, 06:13 PM
I just need someone to check this quick as I'm new to lipos. I just got 2 lipo packs to run in my Nitro MT. They are 2200mah 3S2P. To charge these I want to make a harness to run them in parallel to my charger, and charge at 4.4a right? TIA.
RC10T2 - Novak SS5800 - 7-cell GP3700
HPI RS4 Nitro MT - Mamba Max 5700 - 2S 5500mah Lipo
MRC Thunder King - Mtroniks Truck ESC + Feigao 9L - 3S 6000mah Lipo
squeeforever
squeeforever's Avatar
08.31.2006, 06:16 PM
Yes. Just make sure to balance them.
GeeReg
GeeReg's Avatar
08.31.2006, 06:18 PM
So is it a better idea to charge them separately with the balancer for the first time?
Gustav
Gustav's Avatar
08.31.2006, 06:53 PM
I'd say so,i sometimes charge 2 packs together to about 90%,then charge them to full individually attached to a balancer.The good thing about Lipos is you can charge them the night before.I sometimes run mine days after the charge,i just check them on the charger before i run them.
GeeReg
GeeReg's Avatar
08.31.2006, 07:51 PM
Ok thanks guys. I balanced both with my LBA6. One didn't need any and the other took about 2 min.
jhautz
jhautz's Avatar
08.31.2006, 08:10 PM
If you are going to charge both packs together in parallel, they need to be balanced to each other as well. Make sure the voltage of the 2 ballanced packs is exactly the same before you charge them in parallel.
to make it...
or break it...
Silent...But Deadly
GeeReg
GeeReg's Avatar
08.31.2006, 11:27 PM
Well I charged them but I have a question. When the charge was over it had run for 68 minutes, but only took ~2000mah. After the cells reach 12.6v, the amperage tapers off but it continues charging. Is this normal?
09.01.2006, 12:24 AM
Yup, that's how Lithium charging works. The first stage when the current is constant, but the voltage steadily goes up is the "constant current" mode. The voltage will increase until the pack reaches 4.2v per cell (you are charging a 3s pack right?). Then, the charger switches to constant voltage mode where the voltage is constant and the current steadily decreases until it gets close to 0 amps.
In comparison, NiCD/NiMH uses a constant current mode for the full charge, but uses the fact that the voltage will hit a peak and then start dropping on its own to determine when to stop.
GeeReg
GeeReg's Avatar
09.01.2006, 07:49 AM
Thanks, I'd read about it but wasn't sure. It just seems strange that it takes over an hour to charge a half-dead pack. I'd just assumed that since you charge at 1C, it would always take an hour for a full charge from dead.
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
09.01.2006, 03:49 PM
You don't need to fully charge a lipo pack. In fact it's better not to. Just unplug it when it reaches 4.2 volts/cell volts. That is usually when it's 90% full.
Area 52 Ranch Raceway
T.R.C.R.
