about lipos ,when u say BALANCED what do u mean by that?how do u actually balance the batts?i also saw in the mag that peak racing platinum doesnt need balancing..what lipo batts and charger can u recommend?ill be using it on my savage with quark125b..
and is a feigao 9L motor enough or will work with this esc?
thanks. i dont kno if i have to hijacked a thread or just make a new one so i made 1..
Balanced means that each cell in a pack is of matching voltage.An imbalance can damage the cells.You need a pack that has taps for each cell that are wired to a balance connecter that you plug the balancer into.most work by monitoring the voltage of each cell and discharging cells individually untill they match.There's no standard for balance connectors so you may need an adapter lead to use certain packs with certain balancers.
