links for spur setup
Steelerfan
links for spur setup - 10.01.2006, 05:04 PM
please show me some links for parts to change to a 51t spur gear on my emaxx? thanks
go4gold
mod emaxx
go4gold's Avatar
10.01.2006, 10:09 PM
Are you wanting to use the stock 32 pitch or the mod 1 pitch?
So many toys and so little time
10.01.2006, 10:49 PM
Since he mentions the 51T spur, I will assume Mod1. If so, most setups using the 51T spur also use the strobe slipper setup. Unfortunately, that slipper is almost impossible to come by. You may be able to use other slipper setups though and I'm sure someone else will chime in.
squeeforever
squeeforever's Avatar
10.01.2006, 11:11 PM
I'm pretty sure Leroy said the MGT setup will work without a problem.
Steelerfan
10.02.2006, 08:09 PM
I don't have to have a 51t. I would like less than 64t with 32 pitch. Bought a bunch of 5mm pinions and want to change gearing.
