G2r rear shock issue?
Serum
Serum's Avatar
G2r rear shock issue? - 10.07.2006, 07:18 PM
Anyone else has issues with the g2r and the rear-shocks? The springs on the rear shocks where rubbing against the upper plate like crazy.
Situation;
-Using the P2 rockers
-CF g2r conversion.
Followed the instructions carefully. this wasn't enough. needed to dremel off a bit of the rear bulk to make it a better fit (still not perfect) I needed 3.9mm of spacers underneath the shockmounting thingy to clear the shocks.
the front is a perfect fit, but the rear is not.
I got it working now, but it took more time and effort than needed IMO.
The white line in the attachment shows the problem area.
The aluminum shockholder has the same hight as the stocker, which also failed to work correct. I took notice of the instructions, where it says 'you might need to force the plate a bit to align the holes' I understand this is for the kickup of the rear assembly, but this results in the cf plate being even closer to the shocks.
