What Will I Need To Upgrade
rc-car-crazy
What Will I Need To Upgrade - 04.08.2005, 03:28 PM
Hi i have about to order my g-maxx and i am getting evering the hole job lot and thinking about getting the Plettenberg Bigmaxximum 1800watt what will i need to upgrade to use this motor
MaxxFusion
MaxxFusion's Avatar
04.08.2005, 03:47 PM
Are you completley stock right now?
  Send a message via MSN to MaxxFusion
rc-car-crazy
04.08.2005, 03:48 PM
yea
MaxxFusion
MaxxFusion's Avatar
04.08.2005, 03:51 PM
ok. So you want a list of everthing you need to go with the GMAXX chassis and are going to run the Plenty motor?
MaxxFusion
MaxxFusion's Avatar
04.08.2005, 03:56 PM
SuperMaxx E-Maxx Hardened Steel Idler Kit
This is the center CVDs needed for the extended GMAXX chassis which is highly recommended when going brushless:
SuperMaxx Titanium Center Driveshaft Kit, EXT Electric Chassis
2 - Maximizer 7075 Aluminum Diff Cups
2 - Integy Aluminum Diff Case
2 - Integy Gear Box Collar
2 - Maxx 2.5 Cvds by RD Logics
rc-car-crazy
04.08.2005, 03:59 PM
and if get all that i will eb able to run the Plettenberg Bigmaxximum 1800watt
MaxxFusion
MaxxFusion's Avatar
04.08.2005, 04:04 PM
You will have to get the esc to go with that motor.
I would also recommend you go with Gorilla Maxx G2 X-Brace Motor Mount
Have you looked at the 9L and Warrior 9918 as an alternate solution?
rc-car-crazy
04.08.2005, 04:14 PM
is the 9L and Warrior 9918 a fast motor
MaxxFusion
MaxxFusion's Avatar
04.08.2005, 04:21 PM
Yes its very fast and a lot cheaper. The 9L is for 14 cells. If you are running 12 cells you will want the 8L.
Feigao brushless motor 540 9L
Warrior 9918 Brushless Car Controller
I would suggest going with the BEC so you dont need to run a receiver pack and get the RC Monster Heatsink/Motor Clamp
External BEC/UBEC
RC-Monster Brushless Heatsink/clamp
rc-car-crazy
04.08.2005, 05:14 PM
i have heard of that motor before andheard that soem people do not even have to upgrade anything to run this motor is this true
MaxxFusion
MaxxFusion's Avatar
04.08.2005, 05:21 PM
Partially. You can stay stock for a bit depending on how you drive but you will have to upgrade these parts sooner than later. The high power brushless motors will wear these stock parts quick. IMO you will save yourself a lot of headaches if you upgrade now.
rc-car-crazy
04.08.2005, 05:26 PM
i will bare that in mind
MaxxFusion
MaxxFusion's Avatar
04.08.2005, 05:30 PM
Good Luck
Dafni
Dafni's Avatar
04.08.2005, 06:52 PM
so is this gorilla motor mount also compatible on the stock tranny mounted on the stock cassis?
MaxxFusion
MaxxFusion's Avatar
04.08.2005, 07:12 PM
It is compatible with the stock tranny just not on the stock chassis.
