G-maxx chassis extension
Team X
G-maxx chassis extension - 10.27.2006, 12:41 PM
Can I use the chassis extension on a stock e-max chassis? Also if I don't want the rear skid included with the kit can I just order this:
(GMX04-EX-AL-REARPLATE) G2 Ext Aluminum Rear Plate only?
Thanks
sjcrss
Hyper 7 Erevo Center Diff
sjcrss's Avatar
10.27.2006, 02:16 PM
I don't think you can use the ext. kit on a stock chassis, since it incoperates the x braces.... alos along with the rear upperplate it has 2 posts that stiffen the ext. in the rear.....you can however use a front skid in the rear, in place of the lower skid...because it is the exact...layout as a front skid....except for you have to take the slight bend out of it....I did this for mine...but I used a titanium front skid in the rear, and took the slight kickup out of the skid....looks real nice too....
Bl E-REVO
Quark 125b
Castle Creations-Neu 2200kv motor
((2s2p)(4s)
7800mah 7.4v Lipo Pack
E-Revo 1/8 scale Hyper 7 CD
http://www.rc-monster.com/forum/show...1&goto=newpost
Team X
10.27.2006, 04:22 PM
Ok, Thanks
neweuser
neweuser's Avatar
10.27.2006, 04:28 PM
I would think with some mods, you could use it with the stock chassis.
squeeforever
squeeforever's Avatar
10.27.2006, 04:59 PM
Nah...It wouldn't be worth it really...
neweuser
neweuser's Avatar
10.27.2006, 05:04 PM
True, but it could be done. I had a few extras and had things line up to do it once. But it involved mroe than enough work to do. Like you said, would not be worth it.:005:
Not only that, the stock chassis is not worth extending.
Tupers
10.29.2006, 03:39 PM
When useing the chassis extension I know that you can use a standard emaxx shaft, but what i want to know is has anyone tried useing revo centre shafts as i here that they are stronger.. I know therevo shafts are different sizes but does anyone know if they would fit.
squeeforever
10.29.2006, 04:01 PM
They should.
neweuser
neweuser's Avatar
10.30.2006, 10:09 AM
Originally Posted by Tupers
When useing the chassis extension I know that you can use a standard emaxx shaft.
I would say that the stock shaft would not work in the rear?:032:
sjcrss
sjcrss's Avatar
10.30.2006, 10:14 AM
you can use one of the front or rear shafts and cut them down to size for the middle
Bl E-REVO
Quark 125b
((2s2p)(4s)
