Loctite vs Grinding
natrix
Loctite vs Grinding - 11.03.2006, 03:04 PM
Hey all,
Just wondering what you guys are doing to secure the pinion gears on your motors. Do you use loctite on the shaft in addition to the grub screw? Is anyone else grinding a small flat on the motor shaft so the grub screw has something to sit on? I ground a small flat on my feigao 7xl, but am hesitant to do so on my neu. :032:
Serum
Serum's Avatar
11.03.2006, 03:05 PM
Both..
Grinding the shaft and loctite on the M4 setscrew.
natrix
11.03.2006, 03:11 PM
Thanks for clearing that up. I was also using loctite on the setcrew. I just got a little confused because the instructions that came with the neu said to use loctite on the shaft, but that must be for airplane applications.
neweuser
neweuser's Avatar
11.03.2006, 04:15 PM
IMO, if you plan on changing your gearing, I would use blue loctite. I personally never have used loctite on my set screws for the pinion gear.
Cartwheels
11.03.2006, 05:12 PM
I do niether, never had a problem either.
neweuser
neweuser's Avatar
11.03.2006, 05:15 PM
Not even a flat spot on the shaft?:eek:
aqwut
Brushless Heavy Weight....
aqwut's Avatar
11.03.2006, 05:35 PM
red loctite can be a real pain in the *ss.. I would still se a flat spot and blue loctite.....
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
neweuser
neweuser's Avatar
11.03.2006, 05:39 PM
Yup, in fact, I never needed loctite at all! But if you do use some, use blue. definately a flat spot...:027:
natrix
11.03.2006, 06:05 PM
Thanks for the confirmation guys. I never use red loctite, at least not on my R/Cs. I only keep the blue stuff handy.
Cartwheels
11.03.2006, 07:30 PM
I have not been using flat spots for some time now. Never had any slipping that I know about. No problems what so ever!
Serum
Serum's Avatar
11.04.2006, 04:32 AM
It will slip for sure cartwheels. or you need more power..
sjcrss
Hyper 7 Erevo Center Diff
sjcrss's Avatar
11.04.2006, 08:45 AM
I have had a pinion slip several times when just using a flat spot....it actually walked it's way to the end of the shaft.....so now I use a flat spot as well as blue loctite on the pinion
Bl E-REVO
Quark 125b
Castle Creations-Neu 2200kv motor
((2s2p)(4s)
7800mah 7.4v Lipo Pack
E-Revo 1/8 scale Hyper 7 CD
http://www.rc-monster.com/forum/show...1&goto=newpost
