Project: BL E-Maxx
Josh
Mamba Monster Maxx (Coming Soon)
Josh's Avatar
Exclamation Project: BL E-Maxx - 12.18.2006, 12:27 AM
Who knows when this project will end as the brushless motor/ ESC will be the Castle Creations Mamba Monster Maxx. So only time will tell. From now intel this I will be buying the parts to get my E-Maxx "Bomb-proof". I'm really looking for some help from you guys here at RC-Monster. This is my fifth year in the RC world and I've dealt with BL's before. So I'm "familiar with the scene"
Well here's what I have so far on my E-Maxx
• MIP CVD's all around including center
• Lunsford Titanium Hingepins
• ACNCM Bulkheads front and rear
• FullForce RC: Bearings, Body mounts, Shock boots, and servo skid plate
• Hitec HS-645MG Steering servo
• MaxAmps IB4200 7-Cell packs (Might switch over to Li-Po)
• 7.5 Buggy Diffs but no Diff cases to install them into
Onto the pictures -
My goal here is to give it a racing look but to have it be beating worthy! So a few changed such as the body will be in order.
What I'm looking to buy -
• 17mm hexes
• Ofna Black dish wheels
• Pro-Line Badland MT
• RPM Arms all around
• UE Diff Cases if I don't get FLM bulkheads
• Some Pro-Line body
• Pro-Line Powerstroke shocks
• RPM Axle Carriers
• Some JDCarbon stuff
What I need from you guys is -
• Transmission Upgrades
• Shock Tower suggestions
• Any other information I might have missed
Thank you all so kindly for your time and I hope I can make RC-Monster my new home.
Josh:028:
  Send a message via MSN to Josh
Serum
Serum's Avatar
12.18.2006, 02:47 AM
FLM has got nice shocktowers!
and the singlespeed is a nice add-on with a brushless setup.
Josh
Josh's Avatar
12.18.2006, 03:43 AM
I've been debating off-and-on about getting the GorillaMaxx Single Speed. I've been talking with Shawn and he said the transmission should be just fine. I might add on a RRP slipper for a little extra "security". Will have to see what Santa has got in his bag for the E-Maxx :005:
I have a questions concerning the Hardened steel idler gear I've been reading about it and I see you can buy a pair. Should I do that?(buy a pair that is) I haven't really pried open the transmission since I put the FFRC bearings in there.
Josh :028:
Last edited by Josh; 12.18.2006 at 03:48 AM. Reason: Forgot to mention about the idler
sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
12.18.2006, 09:14 AM
I'm a pretty big fan of RPM, so I'd suggest going with RPM shocktowers. I'm not so sure about getting aluminum body mounts either. Even with my emaxx in stock trim, I manage to flip it on its back a lot, which bungs up the body mount posts quite a bit. I can see how one flip would really mess up an aluminum set. With plastic, I just hit them with the heat gun and straighten them out.
Another thing you may want to look into are the oversized RPM wheel bearing carriers. The full set gets a bit pricy, but they will definitely give you more strength in an area that gets pretty beat to hell.
With the full RPM treatment like that, you should be pretty solid.
Sleebus
neweuser
neweuser's Avatar
12.18.2006, 01:57 PM
I would also get the hybrids, better than the cases and cheaper. I would alos get the steel idler as well as a single speed conversion. If you are looking for JD Carbon hybrid turnbuckles, I have some! Never been used!!! PM me if you are interested.
Procharged5.0
Procharged5.0's Avatar
12.18.2006, 02:09 PM
Nice photos, especially with the leaves.
Josh
Josh's Avatar
12.18.2006, 06:17 PM
Sleebus
I've been planning on getting the axle carriers already so that's on the list. I've recently found out my mistake about the aluminum body posts so they are going off the truck. I'll be trying to order RPM Arms, shocktowers, and the axle carriers shortly.
Thanks. Means a lot! :)
Josh :028:
Josh
Josh's Avatar
12.18.2006, 06:21 PM
I have another question. I am going to ditch those huge bumpers in the front and rear. Should I also get some RPM bumpers to add to the RPM list? Or does anyone preffer something else?
Josh :028:
GorillaMaxx360
GorillaMaxx360's Avatar
12.18.2006, 06:45 PM
-i might be late but anyway- WELCOME TO THE FORUMS
squeeforever
squeeforever's Avatar
12.18.2006, 08:35 PM
One thing people neglected to mention is that the RPM arms with CVD's is a BIG no-no...The arms will flex and the CVD's will pop out and bend the CVD's. I would go with the RPM Revo carriers and 3.3 sliders...
GorillaMaxx360
12.18.2006, 08:49 PM
RPM Bumpers are nice they dont break and if they do you can get a new one for free.
Josh
Josh's Avatar
12.19.2006, 12:49 AM
Are you bassicly saying ditch the MIP CVD's? :019: For plastic ones? I'll do it on one condition. I accept PayPal, when would you like the CVD's :005:
Josh :028:
jhautz
jhautz's Avatar
12.19.2006, 01:56 AM
Nice Project you have going here. E-Maxxes are so fun....:027: SO many options. Its almost limitless.
Couldn't agree more on this one Squee. Bent a few before I learned.
2 things...
Skip the RRP Slipper. Spend the few extra and get the strobe (http://www.rc-monster.com/proddetail...per-Kit&cat=40) and the plastic mod1 spur (http://www.rc-monster.com/proddetail.php?prod=ofn30110) Much better.
If you get the single speed conversion then you only need one steel idler. ;) Even if you dont do the single speed conversion, you will likely only be driving in second gear any way so you could just replace the 2nd gear idler.
to make it...
or break it...
Silent...But Deadly
Josh
Josh's Avatar
12.19.2006, 02:20 AM
If the strobe slipper works as well as it looks . I shouldn't be dissapointed :027:
Thanks for the help and keep the tips coming!
When you are talking about the 3.3 sliders, you are talking about these, correct?
If that's the one then, luckily, I bought a spare for my old Revo so I only have to buy 3 :005:
Josh :028:
12.19.2006, 02:27 AM
If you don't want to get the full single-speed conversion for the tranny, I would definitely get the steel idler as mentioned and also the gear coupler (the do-hicky in the lower right corner):
This will lock it in second gear better than trying to rig the dog gear so it's locked. Also gets rid of the slop from the dog gear.
I don't think Mike has this part listed, but he can get it for you...
