help with mm 5700
t-maxxracer32
t-maxxracer32's Avatar
help with mm 5700 - 12.25.2006, 12:06 PM
hey guys well were opening presents in about an hour and im pretty sure i got the mm 5700 system so i just want to know if there is anything i should do before installing it. like do i need to calibrate anything? or do anything with my computer to install it? do i need to break in the bl motor?
lmk what all there is to do!! thanks alot!
Sylvester
Sylvester's Avatar
12.25.2006, 12:10 PM
All you gotta do is solder on a plug (id reccomend deans) onto the esc and calibrate the esc. No need to break in bl.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
t-maxxracer32
12.25.2006, 12:55 PM
ok cool and how do you calibrate it?
Sylvester
Sylvester's Avatar
12.25.2006, 12:56 PM
You will see once you read the instruction manual, nothing hard really.
Losi 8ight e
MetalMan
MetalMan's Avatar
12.25.2006, 01:06 PM
Do read the instructions, it can end up saving you some time and frustration.
t-maxxracer32
12.25.2006, 01:11 PM
o kk awsome!! also what gearing should i be using? since it has so much torque as it is ill probably rather have more of top speed. i got a bunch of spur gears and pinions for xmas so i have a bunch of options!! lmk what i should do!!
thanks again guys!!
merry christmas to you all!
Sylvester
Sylvester's Avatar
12.25.2006, 01:13 PM
What are you running it in? Im running mine in a B4 geared 20/81 and it is insane on even just 6 cells!
Merry christmas!
Losi 8ight e
t-maxxracer32
12.25.2006, 02:54 PM
im running it in a rusty on 6 cells. ill just mess around with gearing and see how it does!
