My Slipperential's maiden run
sjcrss
Hyper 7 Erevo Center Diff
sjcrss's Avatar
My Slipperential's maiden run - 12.27.2006, 08:28 PM
Well, after getting it all together and the body done....I Charged up some the gp3300 NIMH's (7 cell packs) and dropped them into the truck....and decided to head outside and give it a run up and down the street.....Mind you the road was wet from from the snow melting earlier today...so I figured if the road was a little wet I could see how it handled.....WELL, no matter how hard i tried to get it to wheelie....it just plain wouldn't, also the handling improved so much better to, meaning power from front to rear, was improved greatly to, along with it seemed to corner better as well. So I'm very pleased with the slipperential, and it's worth every penny spent on it..... Below is the setup i was running, when I was just testing it out front....
SLIPPERENTIAL:
revo 40t spur
slipper was tightened down, then backed off by 1/4 turn
30k diff fluid
CONTROLLER:
Micro 2095 BK controller
MOTOR:
Feigo 7xl
16t pinion
BATTS:
GP 3300 NIMH matched 7 cell packs
14 cells in series
TIRES/RIMS
23mm STD offset Rims
Proline Bowtie MT's w/ Ofna Orange molded foams inside
Remember this was on gp's......I'm sure it will do alot better ince I go 4s Lipo next month.....
Well that is the results from my first run....hope it helps you guys....
Shayne
Bl E-REVO
Quark 125b
Castle Creations-Neu 2200kv motor
((2s2p)(4s)
7800mah 7.4v Lipo Pack
E-Revo 1/8 scale Hyper 7 CD
http://www.rc-monster.com/forum/show...1&goto=newpost
