kyosho 44t spur on OFNA Ultra LX center diff
remie
remie's Avatar
kyosho 44t spur on OFNA Ultra LX center diff - 01.05.2007, 05:50 PM
I've got a real quick question.
I saw a cheap OFNA Ultra LX center diff on ebay, and I have allready bought a kyosho 44teeth spur.
does the 44teeth spur fit on the OFNA Ultra center diff?
kind regards remie
Costum Traxxas revo Brushless
  Send a message via MSN to remie
Serum
Serum's Avatar
01.05.2007, 06:08 PM
No, the end of the ofna spur is actually sealing the cup with the O-ring that is used.
But you can simple use a 51T ofna plastic spur and use that instead of the steel one.
remie
remie's Avatar
01.05.2007, 06:36 PM
thanks serum.
but a 51 tooth spur will be to big for the thing I'll be using it.
Gundam-Guy
Gundam-Guy's Avatar
01.05.2007, 08:05 PM
dont the make nylon gears for the lx
coolhandcountry
coolhandcountry's Avatar
01.05.2007, 08:48 PM
Yes the 51 tooth model.
Peace!
Country
Help support the
Rc-Monster
Buy here
jhautz
jhautz's Avatar
01.05.2007, 09:03 PM
Just be careful where you are going to mount the ofna LX Diff. It uses the 51T spur, but it also uses funky size bearings. Not sure waht size it is, but its a different size than every other center diff Ive ever had uses.
to make it...
or break it...
Silent...But Deadly
squeeforever
squeeforever's Avatar
01.05.2007, 09:35 PM
I think there 5x19mm.
Serum
Serum's Avatar
01.06.2007, 05:49 AM
No, not 5 internal, thats the diameter of the shaft.
The ofna uses 5mm shafts and the kyosho spur uses a 6, which is another reason why it would not work.
remie
remie's Avatar
01.06.2007, 08:49 AM
thanks guys!!
I'm going for the kyosho diff instead of the ofna diff!
squeeforever
01.06.2007, 01:03 PM
When I said 5, I meant 5mm wide race.
Serum
Serum's Avatar
01.06.2007, 01:07 PM
that would make more sense.
