losi 8ight -
01.13.2007, 04:05 PM
Just saw the other 8ight on here so I figured I should post some pictures of mine too.:027: It will be running a mamba max with a feiago 9xl c motor. The battery will be 5s 6000mah maxamps pack. So far I only ran it on a 5s 4000mah pack twice but the pack was not up to it so it is getting sent back, (thanks Austin):027: and being upgraded to a 6000mah pack. The motor mount was done my mike.
Then I get the battery back I will have to play with the diff oils. Currently there is still grease in the front and rear, 7000wt in the center. Hope you like it.
