Which ones SIZE
GorillaMaxx360
GorillaMaxx360's Avatar
Which ones SIZE - 01.15.2007, 03:04 PM
1.) Ok if i go with slipperential and non extended chassis what size dogbone works to replace the extended pne for the back 101mm or 72mm or neither.
2.) Ok if i go with the flm chassis which dogbone do i need to replace the front dogbone the 72mm or the 101mm or neither. I believe on this setup this cvd i need is standard size for the front maxx cvd.
BP-Revo
BMW M Power!
BP-Revo's Avatar
01.15.2007, 03:23 PM
The Slipperential only works with the G2 extended chassis if I'm not mistaken.
crazyjr
crazyjr's Avatar
01.15.2007, 03:35 PM
You can get shorter shaft by asking, says so in the store
GorillaMaxx360
01.15.2007, 03:51 PM
what is the shaft size
