36120 or 3695 + Neu 1512 2Y/F
joeling
joeling's Avatar
36120 or 3695 + Neu 1512 2Y/F - 01.24.2007, 04:35 AM
Hi,
I am looking for my next BL setup for a buggy & I'm considering either the BK36120 or 3695 in combination with a Neu 1512 2Y/F (1400kv) motor using 8S 4000mAH 20C lipo. Do you think this combination will work out ok ?
I've tried the lower voltage - higher current route but have only met with limited success as I live in the tropics where temperature & humidity is relatively higher.
In addition, I read that the rpm limit of the 36120 is 42000 while there is no indication for the 3695. How hard & fast is this spec. ?
Regards,
Joe Ling
