Go Back   RC-Monster Forums > Support Forums > General Nitro
what to use to clean engine
t-maxxracer32
t-maxxracer32's Avatar
what to use to clean engine - 01.30.2007, 05:52 PM
hey shoudl i use degreaser to clean the engine or what? (i wannt to get all the rdirt and crap off the engine)
thanks
pinolelst
01.30.2007, 06:05 PM
In the past I've used simple green..... nitro clean from the local hobby shop...and alcohol in a spray bottle (nitro clean is just alcohol in a spray can )
pinolelst
Procharged5.0
Procharged5.0's Avatar
01.30.2007, 06:36 PM
Trinity makes "NITRO BLAST" it works well. Try to use the nitro cleaners in a open air environment. Some have strong fumes.
t-maxxracer32
01.30.2007, 10:21 PM
kk will try that nitro blast!
Mike.L
Mike.L's Avatar
02.02.2007, 09:25 AM
some wd40 also should help.
  Send a message via MSN to Mike.L
HotnCold
HotnCold's Avatar
02.02.2007, 09:50 AM
I would use simple green and a bristle brush - not the orange stuff - or if not - use denatured alcohol - dries super fast - dosent harm any electrical stuff if comes in contact with and generally works well. And when your done - a light coat of wd-40 is not a bad idea - it will make the dust stick a little more - but will clean off easier - catch 22 - .... Good Luck...
Hows that "Hope and Change" working out for Ya???
neweuser
neweuser's Avatar
02.02.2007, 04:43 PM
I use the Nitro blast, it works well. I hae also used Simple green, which is a great alternative with a tooth brush :)
t-maxxracer32
02.02.2007, 05:23 PM
i just went to checker automotive and got some break cleaner. used it on my freinds little rusty and it cleaned up really nice. didnt use it on my revo cause idk if it messes it up or not lol....
will it harm the revo? (also i got the dechlorinated one) so it doesnt leave any white marks.
neweuser
neweuser's Avatar
02.02.2007, 05:24 PM
I wouldn't use it, the motor has rubber seals that will shrink. They go back, but you'll have to redo them all. I know, I learned by mistake! LOL
Procharged5.0
02.02.2007, 05:25 PM
Brake Cleaner (most brands) will eat plastic parts. I do not recommend it. It's not good to breathe either.
Procharged5.0
02.02.2007, 05:26 PM
Newe! Dammit! You beat me to the post again! Your up 2-1.
t-maxxracer32
02.03.2007, 12:48 AM
lol well i got the stuff that doesnt eat plastic (well it hasnt eating anything yet!! HAH!! i take the engine out when i clean everything too............. if that means anything. and ya ik i think i got high the last time i did it! lol just kidden but ya i was in my room with the windows down and door closed.... not too smart... now i leave the window open!!
ill buy some nitro cleaner so we will see what happens!!
renny
if you build it.... Then I can break it
renny's Avatar
02.06.2007, 01:36 PM
thats all I ever use and it hasent let me down yet.
plus it evaporates quick.
glassdoctor
TEAM FUSION
glassdoctor's Avatar
02.06.2007, 01:56 PM
If you have access to an air compressor, one thing my buddies swear by is to use a light sprtiz of simple green... then blow it off... then a light spray of WD40...and blow it off.
This gets the it clean, protects from any corrosion, and makes it look like new.
This may not work for a neglectly filthy truck, but it works great if you do it regularly.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
squeeforever
squeeforever's Avatar
02.06.2007, 09:51 PM
What I do, and it works GREAT, is I simply take the engine all the way apart and simply soke it in old nitro fuel that is to old to run...Works great...
