BL Motor Evaluation program
GriffinRU
BL Motor Evaluation program - 02.11.2007, 02:45 PM
Writing a program to simplify BL motor selection. In general I have an idea what to plot and which parameters to display, but would like to hear others as well. First iteration will be focused around 540 Feigao motor but later database can be extended including custom motors (user will specify motor parameters).
There are plans to import Lehner .xls files direct from web or just add them to database, similar can be applied to Hacker and Kontronik motors, need to check for Neumotors data.
Attached printscreen shows 540 7XL perfomance, rated and full (theory)
Artur
ID:	2411   Click image for larger version
02.11.2007, 02:48 PM
Very nice! What are you using to get the measured numbers?
GriffinRU
02.11.2007, 03:07 PM
Using DC motor model and NI LabVIEW software for programming.
Motor parameters: Kv; I no load; I max; R and L
Later motor dimensions to calculate rated power and no load current plus nominal voltage.
Heat dissapation and heat sink size also on the way. Plus ESC switching freq and connectors resistance...
Artur
02.11.2007, 04:59 PM
Sounds like a good thing to have. Now, someone needs to make a BL dyno to validate the calculated results. :)
GriffinRU
02.11.2007, 05:24 PM
This one will help to understand how it works plus rated powers and alot more, dyno will prove only one particular setup/given motor.
Artur
P.S. I need to make program installer smaller, for now it is 70Mb, way to big for publishing and downloading... :( (Program itself 2.41Mb) Windows business...
Serum
Serum's Avatar
02.11.2007, 05:36 PM
Awesome Artur!
this will be a big thing IMO!!
You can use some kind of a 'wise installer' you can start this software, install things, change things in the register etc. and after that, it creates an executable file of all the things changed, this file is the install file.
Again, great work Artur!!
GriffinRU
02.11.2007, 05:39 PM
Originally Posted by Serum
Awesome Artur!
Thank You, Rene, I am working on it...
If not today tomorrow I will put alfa version :)
Artur
Download, requires NI 8.2 Run-time Engine
02.11.2007, 07:23 PM
Argg! You have to register to get the runtime. And then, it's a 94MB download (and the server is pushing it at me at only 365kB/s)! I really hope it's worth it! :p
Serum
Serum's Avatar
02.12.2007, 09:52 AM
Great Artur!!!
I'll download it when i get home! great, looking forward to have a closer look..
It's not in Russian!? my russian would be less good than you English.. :p
glassdoctor
TEAM FUSION
glassdoctor's Avatar
02.12.2007, 10:44 AM
Wow, a 90MB download for a 2.4MB program, yikes. Looks very cool... I haven't got it yet.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
sjcrss
Hyper 7 Erevo Center Diff
sjcrss's Avatar
02.12.2007, 11:39 AM
I just downloaded it.....very cool...great job
Bl E-REVO
Quark 125b
Castle Creations-Neu 2200kv motor
((2s2p)(4s)
7800mah 7.4v Lipo Pack
E-Revo 1/8 scale Hyper 7 CD
http://www.rc-monster.com/forum/show...1&goto=newpost
neweuser
neweuser's Avatar
02.12.2007, 12:14 PM
Another very useful tool! Great Job! The more info the better!
GriffinRU
02.14.2007, 09:54 PM
I am sorry for size...
But here comes an update, no more NI and 2 versions one with full-blown installer and another just files required to run (keep them in the same folder).
Download Full installer (8.93MB)
Download Just program (5.58MB)
Artur
pinolelst
02.14.2007, 11:25 PM
Very cool...graphs and charts...submenus for different displays ....thanks
Seems like you have the entire Feigao line covered but is there anyway we can add motor data ??
thanks again
pimolelst
Aragon
02.15.2007, 05:00 AM
This is great. Is temperature in faranheit or celcius?
You should allow for higher voltages too. Up to 50V should be plenty.
