What could've caused this?
bigconig
What could've caused this? - 03.14.2007, 08:01 PM
I was running my MM5700 rustler at lunch break today when it started glitching real bad and the brakes stopped working. I pulled the body with the wheels off the ground I tried the throttle it cogged real bad a couple times then spun the wheels pretty good, but still no brakes. I figured I would just put it away and worry about it after work.
I got home and threw the pack (gp3300) on my charger- the charger gave the message "no battery". I decided to put the pack back in the truck and see what was up since it was working a few hours earlier. as soon as the plugs touched the wheels spun (power switch was off) and the PCB started to smoke right by the LEDs- I pulled the plug (I hadn't even got it all the way plugged in) and was like WTF. threw in a cheapy 1500 that I knew had a good charge and nothing.
The motor is fine as it works with my other MM esc- it's obvious that the battery and ESC are toast but what do you think caused it? bad battery smoked the ESC or vice versa? bad switch? I'm at a loss
glassdoctor
TEAM FUSION
glassdoctor's Avatar
03.14.2007, 08:30 PM
Got me...
One thing I can say is that I have seen the brakes go out on the MM before... but the battery thing?????
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
MetalMan
MetalMan's Avatar
03.14.2007, 11:16 PM
Contact Castle, and they'll do something about it. This obviously is not normal...
