03.24.2007, 01:20 AM
To get the sliders to fit, you need:
1. Slider axles (3.3)
2. Turnbuckles all around (3.3)
3. Axle carriers all around (3.3)
4. Maybe new arms, unless you lower it most of the way.
5. If it is a new emaxx, that's it, as it comes with the 4 bolt diffs.
Bonus: it makes the emaxx one inch wider.
You may also want to upgrade the center shafts with the old front or rear driveshafts: the reason the stock shafts twist is that the small insert does not travel the whole length of the large part (does this make sense?). To correct this, take the old front or rear small insert (that you replaced with the 3.3 sliders) and cut it so that it is longer than the stock center small insert but short enough not to bind.
Other than upgraded diffs, this should be able to handle a modest brushless system or at least 14 cells on the titans and evx.
