5s 1p A123 pack test, 16.5v, 2300mah...
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
5s 1p A123 pack test, 16.5v, 2300mah... - 04.02.2007, 11:02 PM
Here is a link to the screenshot taken with an eagletree.
Click HERE
Not too shabby, considering only 2.3Ah capacity!
However, the voltage is off a bit, when i put them on fresh, it says 16.7 volts, the pack would actaully be at 18 volts then. So you can add a certain percentage to that, I'm going to try to calibrate it.
glassdoctor
TEAM FUSION
glassdoctor's Avatar
04.03.2007, 10:09 AM
Interesting... you think the calibration is that far off? Check it against a couple other voltmeters if possible.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
zeropointbug
Z-Pinch racer
04.03.2007, 10:55 PM
Well, does 16.7volts, and 18 volts seem off? But i've tried calibrating it before and it seemed like when i ran the thing, the voltage was very 'noisy'.
glassdoctor
TEAM FUSION
04.03.2007, 11:15 PM
Does the charger have an lcd screen? Some chargers will show the voltage whenever the pack is connected even if it's not charging. This way you could see what it reads the voltage at.... then plug it into the eagletree in live mode and see what it says.
Also are you sure the charger is getting them to exaclty 3.6 per cell?
16.7 vs 18.0 is too far off to be "right"
The voltage will fall off from 18 pretty quick... but hot off the charger it should be there.
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
zeropointbug
Z-Pinch racer
04.03.2007, 11:21 PM
Yah, the A123's will hold the 18volts for days it seems right off the charger, i think they have the lowest self discharge on the market. The power supply i am using is set to exactly 18 volts (LCD, yes), this thing is deadly accurate. It has to be the eagle tree... I'm gonna play around tonight to see if i can get it working properly. thanks
Serum
Serum's Avatar
04.04.2007, 01:52 AM
can't believe the eagletree is that far off. can you measure the pack with a voltage meter while hooked onto the vehicle?
zeropointbug
Z-Pinch racer
04.04.2007, 03:44 AM
I just topped up the pack, after i took it off it was still 18 volt. Okay, this time it is saying 17.6 volts? what is going on? I wasn't hooked up to a vehicle, i was doing a bench test with my old 820 dewalts, they can take alot of current running nothing but themselves, those selfish brushed hooligans! :005:
