Something never seen before (I think)...
Something never seen before (I think)... - 05.17.2007, 11:47 PM
Before I get into this, I want to say that this is NOT a serious project by any means. It was just one of those whimsical things that grab me from time to time.
A while back, I was driving my Revo around the yard while listening to headphones when a car went by with a booming stereo. So, I figured: Why not install a stereo in the Revo? An idea was born.
And just in case you think you didn't read that right: Yes, a stereo in a Revo.
First, I started by tearing apart a set of old computer speakers that had a blown internal amplifier. So, now I had a 2.5" full-range driver. Not exactly deep bass material, but whatever.
Since the Revo doesn't have much room on the inside, I thought I'd make a speaker box that would sit in the rear "bed". After making a few measurements and a trip to Lowes for fiberglass resin and some thin wooden dowels, and a trip to Wal-Mart for some fleece, I started assembling the box. The pics below show some of the various stages of the fabrication.
The wooden frame made of 1/4" square dowels with fleece wrapped around it:
Several layers of fiberglass inside and out and a bit of sanding:
Test fitting the driver. Perfect fit!
After a little textured paint (to emulate speaker carpeting), a speaker gasket, and some port tubes:
I didn't have any Theille-Small parameters for the driver, but I figured I'd make the box as big as I could and then port it for a little extra 100Hz response. The result was adequate at best. Oh well. Can't make a hi-fi out of junk I guess.
So, now I need a car amp.... but to scale. So, an I found a small and cheap 7W mono amp circuit. The amp chip is really designed for low-power car headunits, but an amp is an amp right? The IC will work well from ~8v all the way up to 18v+, but needs at least 14v to get the rated 7W out on a 4ohm load. Easy enough on 14 NiMH cells I think. After some assembly and shoe-horning into a RadioShack enclosure fitted with appropriate connectors:
Internals. Pretty basic stuff. You like the blingy gold heatsink?
The amp all buttoned up:
The amp and "subwoofer" box together for size comparison:
So, a little velcro to hold down the box in the Revo truck bed, a little power wiring to my batteries, and hookup to a tiny flash-based MP3 player is all that is needed to have tunes while zooming around! Please don't mind the poor Crowdpleaser paintjob - artistic flair is not my strong suit!
A last pic showing the box mounted in the truck
Yeah, the sound isn't the best, but is surprisingly loud when running around. Of course, you wouldn't want to race or bash with this stuff on there, but it was a fun project nonetheless. :)
Maybe with a nicely painted hummer body, a true stereo would be an interesting project. Maybe even have a true subwoofer. :)
