Brushless 4-Tec
akratz1
Brushless 4-Tec - 05.24.2007, 06:07 PM
I have a MM 5700 just running on a 6 cell pack, with around a 6 to 7 ratio. The tires came off the rims. Is there some glue that holds better than others or some kind of rims like the bead lock rims for the monster trucks for touring cars.
jnev
jnev's Avatar
05.24.2007, 06:17 PM
I have never seen touring cars use bead locks. It is used more on mt's or scale crawlers. What glue did you use? I usually use "CA glue" from my local hobby shop.
Re~Mix
ĄGo Baby Go!
Re~Mix's Avatar
05.26.2007, 09:41 PM
CA Glue or super glue tends to work fine. Guys run sedans around 80mph with just the glue holding...so you should be fine. It's likely the stock rubber and factory gluing job that is messing things up.
Nice to see another 4-tec, I had a brushless one a long time ago, however, after a failed custom chassis I gave up.
RC18T FT - Quark Castle Creations Airtronics IB
  Send a message via AIM to Re~Mix
akratz1
05.26.2007, 10:19 PM
I went ahead and super glued them, holding fine. The things fast all I have done is ran it back and forth in a parking lot. It's hard to control, its a used chassis so I guess I need to overhaul it. Anothe thing is that the stick packs I'm using are getting so hot there melting the plastic on them, not sure if it's effecting the cells themselves yet, I havent opened one up. I plan on gettng some lipos but shouldn't 6cell NiMH hold up.
supralover72
supralover72's Avatar
05.27.2007, 01:00 AM
You need deans ultra plugs.
captain harlock
RC-Monster Captain
captain harlock's Avatar
05.27.2007, 07:30 AM
I'm still planning to do a Mugen or a Kyosho 1/10th on roader( 1/8 is too big for me). I use the Vortex super glue and it's incredible.
Nice to meet you!
akratz1
05.27.2007, 11:41 PM
I have deans plugs. It's not melting the plug its melting the endcaps. Also should I put a UBEC in, what will it help?
Finnster
KillaHurtz
Finnster's Avatar
05.28.2007, 09:54 AM
Sounds like a cheap stick pack with high resist cell tabs. You draw so much current they get hot and start to melt things. Side by side packs w/ batt bars would hold up, but lipo would be even better.
seth556
RC-Monster Silicon Carbon
seth556's Avatar
05.28.2007, 12:06 PM
You can always cut the end of the pack where the end cap is. Cut it off and then pull the thin metal pieces that are on the end of the cells off. Then solder the wires directly to the cells.
  Send a message via AIM to seth556
