1/8 diff
dadnjesse
1/8 diff - 06.02.2007, 09:04 PM
Im using the flm bulks with the 1/8 difs. Do I need to put lube on the pinion inside the combo bulks? Im thinking I do but I want to make sure.
GorillaMaxx360
GorillaMaxx360's Avatar
06.02.2007, 10:35 PM
yes i used just any old red grease, but most recommend black grease but make sure you put a good amount in there so you can feel some friction so when it wears down you still have some grease on the pin and diff bevel gear.
dadnjesse
06.02.2007, 10:58 PM
thanks
GorillaMaxx360
06.02.2007, 11:12 PM
anytime
