Transmission
olafjak
olafjak's Avatar
Talking Transmission - 06.05.2007, 04:29 PM
Hello,
New here but i have read a fair bit about mt owned a SS 4.6 and 1:5 scales but now have a thing for electric.
bought an E-zilla and loved it. want to go BL with my new project a Traxxas t-maxx (bought a secondhand for bout 150 USD):027: :027:
Now i want to know something about the trans for this car.
I had the 2.5 T-maxx trans but sold it.
Now however i want to buy an e-maxx transmission but my question is the following (couldnt find it on the forum) what transmission can u use besides the e-maxx one???
can u use an 2.5 t-maxx or a 3.3 maxx transmission without to much mods ??? or do you need to make friends with your dremel ????
Anyways thanks for your advice:036: :036:
Procharged5.0
Procharged5.0's Avatar
06.05.2007, 05:10 PM
Welcome to the forums! You are in the right place fo tech info!
All three will bolt in.
If you are using electric motors (brushed or brushless) install the emaxx trans with RC-Monster steel idler gear(s). That is "THE SET-UP" to use for bashing and/or racing. If you are racing only (assuming you are running brushless) you can also use a gorillamaxx single speed conversion which is based or the E-maxx trans as well.
06.05.2007, 05:21 PM
To add to that "the set-up"; a GOOD slipper set. Something like the strobe works very well...
Procharged5.0
06.05.2007, 05:27 PM
Thanks Brian. I should have mentioned that.
06.05.2007, 05:32 PM
That's OK, I've got your back. :)
GorillaMaxx360
GorillaMaxx360's Avatar
06.05.2007, 10:10 PM
don't forget to strengthen up the output gear by replacing the roll pin with a hex screw or bit.
transmission
olafjak
olafjak's Avatar
Talking transmission - 06.06.2007, 02:20 PM
Ok thanks u guys,
So i see a lot of 3.3 transmissions on e-bay they will just bolt right in then ???
I have an order with Jamie from starluck for a BL setup.
Also what do you mean with the output gear ??? the big spurgear ???
srry for this but only had experience with nitro and gasoline trucks/cars.
so besides an e-maxx transmission can u also use either the emaxx trans with RC-Monster steel idler gear on a 3.3 transmission ??? or does the rc-monster set come with the trans ???
anyways thanks for the info.
Olaf:026: :026: :026:
GorillaMaxx360
06.06.2007, 02:47 PM
By output shaft i mean in the Emaxx trans there is the top shaft that has two gears on it they are both held together with a roll pin. This often breaks so people replace the pin with a hex wrench piece or a drill bit. If you decide to go with the Emaxx trans you will need one steel idler if you decide to go with a single speed option which is best for Brushless anyway(2 idlers are needed for dual speed) you will also want to strengthen the output shaft with a stronger pin like and Allen wrench or drill bit. You can also go with the single speed when using the Emaxx trans. I am not very familiar with the nitro transmissions but if i am not mistaken the idlers from mike wont work(but i could be wrong) and the single speed conversion would not work for sure. The RC monster idlers come separate, and the single speed comes second but these only work with the Emaxx trans i believe. O and since many people here do not use a maxx trans i am not as familiar with them but i don't believe you have to beef up the output shaft in the nitro trans but not sure. hope i helped a little.
ClodMaxx
hold my beer... watch this...
ClodMaxx's Avatar
06.06.2007, 06:49 PM
as to what gorillamaxx360 was saying for an emaxx transmission, look at this. it's the input shaft. the gear on the left (the endmost shaft pinion gear) is for 1st... and the one on the right is for 2nd gear, which will be used much more often for BL. the little pin holding the gear to the shaft is a flimsy press-fitted piece of metal. that's the part that could need the modification that gorilla is talking about.
Eflite Blade 400 heli on 3s
Procharged5.0
06.07.2007, 11:10 AM
They can use upgrading. I do that as a standard part of my "HSR MOTORSPORTS" input shaft package.
transmission
olafjak
olafjak's Avatar
transmission - 06.07.2007, 01:13 PM
Ohhh sweet mates just love this info.
so how much would a decent setup set me back (also if you could list the items maybe :027: :027: :027: :027: )
that would be awesome.
Thanks anyways for the input
GorillaMaxx360
06.08.2007, 11:41 AM
what a decent trans for the maxx 3.3 or a E-Maxx. Well here is a list for everything you would need for a bullet proof Emaxx tranny.
1. E-Maxx Gear Box Stock $10 (stock will defiantly hold and will cut down on weight) Here
2. GorillaMaxx Single Speed Conversion Kit $75 (this will lock your trans in second gear, and you want this because the Brushless motors these days are so powerful it just blows right past first gear and it becomes useless) Here
3. OPTIONAL -if the G-Maxx single speed is more than you want to spend than you can use the stock trans case and just buy the coupler that they make that is only $12 Here
4. E-Maxx input shaft $7 Here
5. Modify Input shaft and replace roll pins $0 a half an hour working with your hands removing the pin and making minimal grinding to a hex wrench or drill bit and then pressing it into the hole where the roll pin is (this upgrade greatly helps because the roll pins usually snaps under high power Brushless systems.
6. RC monster Steel Idler $15 (not much to say here just put it in and go) Here
7. Second gear for Emaxx trans $3 (plastic holds pretty good so metal in not necessary) Here
8. E-Maxx Idler shafts $4 Here
9. Bearings = (4) 5x11 (3) 6x12 $9 at your local hobby shop to get these in sealed bearings
10. Motor Mount Stock $8 Here Hopup $17 Here
11. Misc screws for Assembly
That is pretty much everything to bullet proof and lock and emaxx tranny into second gear for brushless. I am not sure about the other trans but they would probably be much more expensive because there are whay more gears, shafts, bearings, ect... for example look here and thats just how much a stock 2.5 trans costs and the 3.3 is bigger.
Hope I helped
ClodMaxx
ClodMaxx's Avatar
06.08.2007, 12:24 PM
dang, G - nice job. that must've taken a couple minutes, lol.
GorillaMaxx360
06.08.2007, 01:04 PM
yeah it did. Thanks
olafjak
olafjak's Avatar
06.08.2007, 03:53 PM
Sticky ??? on tansmission upgrades ???
Admin plzzzzz
