feigao 540c 8xl dimension
uarghhh
feigao 540c 8xl dimension - 06.05.2007, 06:10 PM
can someone give me the exact dimension of an feigao 540c 8xl motor? (screw hole ect,,,) I don't want to wait to have my motor to make my motor mount... thanks :)
jhautz
jhautz's Avatar
06.05.2007, 06:15 PM
http://www.feigao.com/sdp/85838/4/cp-102735.html
EDIT: Sorry you said 540C
That drawing is still good for overall length screw hole location and shaft size/length. The 540C is bigger in diameter because of the cooling fins. IIRC its right around 40mm in diameter with the fins. I can measure later tonight when I get home if you want.
The 540C also has a small collar around where the shaft comes out of the motor. Its 1mm tall by 19mm diameter if IIRC. I can measure that too if you want.
That should at least get you going.
to make it...
or break it...
Silent...But Deadly
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
Mounting holes are:
25mm apart
39mm small diameter (motor shaft end), plus the fins over that...
72mm long (not including shaft)
uarghhh
06.05.2007, 06:17 PM
thanks a lot guys!
uarghhh
06.07.2007, 02:18 PM
jhautz, yeah if you could take mesure of the diameter with the fins and the collar too... thanks a lot..
it keep me busy while waiting 2 weeks to receive my order!!!!
jhautz
jhautz's Avatar
06.07.2007, 04:23 PM
I apologize I forgot about those measurements. I'm traveling intill Sunday and won't be able to get them for you untill I. Get back. If someone else can get them before then, please do. If not ill get them for you when I get home.
to make it...
or break it...
Silent...But Deadly
zeropointbug
Z-Pinch racer
06.07.2007, 05:06 PM
I gave you the dimensions up there, the fins diameter is 43mm.
uarghhh
06.07.2007, 09:21 PM
tnk a lot zeropoinbug!
zeropointbug
Z-Pinch racer
06.07.2007, 09:25 PM
Do you have a CAD program? I can send you a perfect model up of the 540C motor.
uarghhh
06.07.2007, 09:30 PM
ho my! I have autocad 14... kinda old but I will give it a try!
zeropointbug
Z-Pinch racer
06.07.2007, 09:35 PM
What file type? I can send STEP, STL, or ACIS.
uarghhh
06.07.2007, 09:41 PM
Mmm.. my current version can't open this format.. Pretty lame, was just what I needed...
