5mm bore 32 pitch pinion gears -
06.15.2007, 06:41 AM
I was wondering if you had any of the sizes in stock? The website just says out of stock so I wasn't sure if that meant all sizes or not. If none are in stock when are you expecting more to arrive. Thanks.
"The 32 pitch gears should be here this week. The Mod1 should b plentiful again in a week or so as well – all gears are in process and waiting for heat treat or a similar final operation. J
