Lithium Polymer cells
Major Azzwoopin
Lithium Polymer cells - 06.20.2005, 06:42 PM
Anyone here thought of, or are currently, making their own LI/POLY packs??
Lipoly 2250 Cells/Packs
New 15C Max Burst Lipoly Mid-Large Scale Cell
2250mah Capacity
3.7 Volts
35mm X 105mm X 5mm
Rated at 33 Amps Max Burst
41 grams
I found these at
http://www.maxamps.com/
I may try some out. You can build your own 4S4P for around $144 bucks
that would be a 14.8v @9000mah peak current at 132 amps burst or approx 60 amps continuous
or a 5S5P would come out to $179.90
18.5v @ 11250mah peak current at 165 amps burst
75 amps continuous
I bet we could get a good bulk buy package price from them.
anyone interested.
I'll look into a welder for custom making packs and adding balancers into a pack
 Send a message via ICQ to Major Azzwoopin Send a message via AIM to Major Azzwoopin
MetalMan
MetalMan's Avatar
06.21.2005, 09:46 AM
I have built my own Lipo pack using those cells. It is a 3s2p. The cells really are great, and even have taken some damage (which is known to make them puff, but I got lucky). Just so you know, your prices are way off. For a pack, you multiply the "s" number by the "p" number. For example, you have 4 "p" blocks which consist of 4 cells in parallel. The 4 blocks are then put in series to give 14.8v. So, for a 4s4p, you need a total of 16 cells, bringing it to $280. For a 5s5p pack, it would cost $450. If you would like some further explaining, I can draw up some pictures for you.
Serum
Serum's Avatar
06.21.2005, 05:44 PM
Your calculations are wrong. A 5S5P would take 450 dollars.
What you calculated is a 5S2P... (you need 25 cells for a 5s5p pack..)
Soldering them is not a problem though.. Maxamps can do it for you.
MetalMan
MetalMan's Avatar
06.21.2005, 11:49 PM
They do charge a little extra for that though. But, they would most likely cut a deal because the pack is so large. They cut me ~$15 when I ordered 6 2250mah cells.
Major Azzwoopin
06.22.2005, 12:11 AM
OOOPS brain cramp...wasn't picturing the multi dimensional image of batteries in series and in parallel properly
Too much researching parts lately
Serum
Serum's Avatar
06.22.2005, 03:04 AM
:D
It is time consuming, digging on the internet in the hunt for the right stuff..
HeavyMetal
06.30.2005, 09:17 PM
When I get Li-Po's i'll probly get ones that have like 6000mah.:D
  Send a message via Yahoo to HeavyMetal
Major Azzwoopin
06.30.2005, 09:35 PM
I have been doin nothin but research this for the last few weeks
I'm gonna give it a whirl
Tell me if I got it right fellas.
It appears that it is smarter (performs better)to go with the LIPO's (Kokams) that have the highest "C" rating or ability to release there voltage at the highest current rate and then add another set of them in parallel to get the longer MAH rating.....for instance...... you can get a group of cells from polyquest that each cell has a rating of 6000 mah.....the high MAH was the most significant factor in battery selection before ........but these polyquest cells only have the ability to release there stored voltage at a discharge rate of 15 to 18 "C" which will be significantly less amperage to your motor than a KOKAM 3200 mah 20 "C" pack. They both will deliver the voltage..but the one with the highest "C" rating will get you the more "UUUMPPPPHH"
so now in order to match the polyquest 6000mah rating or its ability to retain its charge and voltage for longer run times you just add another set of KOKAM's in parallel and that will give you the 6400mah run time at the higher amperage "C" rating.
So for right now KOKAM 3200's in their SUPER HIGH DISCHARGE class or 20 "C" are the cell that is on top
Close??? right????
MetalMan
MetalMan's Avatar
06.30.2005, 11:16 PM
Your ideas are correct for the most part. a 6400mah pack would still be capable of 20C though (128amps). But, the Kokam 3200mah 20C packs actually only give out ~3000mah. But it seems like these cells are very good for use with RC cars because they can take high burst currents.
HeavyMetal
07.01.2005, 12:00 AM
Check out this pack http://stores.channeladvisor.com/rc-...itemid=2101115 What do you guys think of it.
Never mind the output current isn't high enough.
what would give me about 20 min run time with a Warrior 7018 and a Feiago 8s
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
07.01.2005, 09:30 AM
What vehicle? Those packs would deliver the current in a small vehicle like a rustler or pede and could probably make a 20 minute run with the right gearing as well.
HeavyMetal
07.01.2005, 12:50 PM
Which one is better the two cell or three cell. (stupid question i know)
RC-Monster Mike
Site Owner
07.01.2005, 12:56 PM
The 3 cell would be pretty insane with the 8s motor.
HeavyMetal
07.01.2005, 01:09 PM
How many Li-Po cells can the Warrior 7018 handle?
RC-Monster Mike
Site Owner
07.01.2005, 01:19 PM
6s, with the appropriate motor(not 8s!).
