Neu 1512 2.5d + MGM Compro 80?
Offroader73
Neu 1512 2.5d + MGM Compro 80? -
06.27.2007, 04:50 AM
Hi
Before I order, can anyone tell me, if this setup will work on:
Ligthning Stadium Track Pro-R
12 Cells 4200 mAh
-Neu 1512 2.5d/f (2000kV)
-MGM Compro 80 amp (needs no separate BEC, right?)
I want a MGM because I don't like any BEC receiver packs.
DOES the MGM handle:
Forward + Break + Reverse
If it's ok, I am ready to order!
Best regards
Tom
Offroader73
Find all posts by Offroader73
2
Xtremespeed
08.28.2007, 07:36 PM
I may be off here, but I think you would have heat issues with the 80 amp. A lot of people are cooking esc's that handle more amperage than that. I would look at the 16018 if you want a MGM, or you could try the MM or Quark 125.
Xtremespeed
Find all posts by Xtremespeed
Linear Mode
Switch to Threaded Mode
