mamba max bullets
sweet86
brushless newbee
mamba max bullets - 09.05.2007, 10:11 PM
well found out all along it was a lose motor connection so i stripped down the heat shrink and when it started to glitch i found that the leads were really hot. didnt know if you guys know any way to get rid of the factory bullets. i run deans connectors on all of my brushed motors but now i have 3 wires dont know of any sugestions.
thanks
kyle
09.05.2007, 10:27 PM
You can either solder the wires directly to each other, use power poles, or larger connectors. If you decide to solder the wires directly, temporarily hook the wires together to make sure the motor spins in the right direction before soldering for good.
For direct soldering, I find these to work well. Just cut off the plastic housing and solder the wires into the metal part (don't crimp). Once heatshrunk, it makes a nice clean inline connection.
bdebde
That's All Folks!
bdebde's Avatar
09.06.2007, 12:27 AM
I just use the female plugs and remove the male plugs, and solder the wires from the male plugs into the female. I usually cut the female plug shorter too.
