Fiegao/ Nemis motor help.
bb16
Fiegao/ Nemis motor help. - 09.09.2007, 08:25 PM
Im lost a part when the endbell on my nemisis blue motor fell of. Its that bushing/ spacer that goes on the shaft before the endbell pops on and it stops the shaft moving side to side. Anyone know where i can get a spare one of these.
On the plus side brushless has been great compared to nitro.
09.09.2007, 08:57 PM
Well, I have an extra one of the shorter ones you can have. It looks like it goes on the back end (they are different lengths). Judging from the shaft markings, the front one looks like it was a hair under 8mm long. The one I have is about 5mm long.
If you can find some brass tubing, you could cut the length you need with a pipe cutter or something. The exact dimensions are 5mm inner diameter, 7mm outer diameter, by whatever length.
bb16
09.09.2007, 09:02 PM
So is the front one a different length than the front one?
I lost the back one.
09.09.2007, 09:08 PM
Yeah, they are different lengths. The one I have is the back one, and it's just under 5mm. You might want to measure your to make sure. Even though it is missing, there should be markings denoting where the spacer was.
If it'll work, PM your mailing address and I'll send it to you via mail.
bb16
09.09.2007, 09:40 PM
It not 8 so its 5 i guess pm sent
Thanks
