Video
phidailo
Video - 09.16.2007, 07:59 PM
finally got a chance to get a video of my crt. the first link is a solo run. As you can hear the landings are pretty hard with the stock shock oil and preload half way down. Have you guys been having to increase the shock oils at all with a brushless setup? I have 1515 2.5/d neu, quark 125, and 4900mah evo25c.
The second video is with a couple nitros.
I'm a noob when it comes to driving but enjoy!
http://www.youtube.com/watch?v=vNqRRmFW_so
http://www.youtube.com/watch?v=Ihc1sgyCyHw
  Send a message via AIM to phidailo
squeeforever
squeeforever's Avatar
09.16.2007, 08:09 PM
Nice videos! Try heavier oils and more pre-load in the back so it doesn't nose drive.
FG101C
09.16.2007, 09:06 PM
Whats funny is you can hear someone trying to get a nitro started in the background. Cool vids.
snellemin
2 KiloWatt RACER
snellemin's Avatar
09.16.2007, 09:07 PM
Nice vids man. I've been there once. too far for me to drive to.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
glassdoctor
TEAM FUSION
glassdoctor's Avatar
09.16.2007, 10:51 PM
Nice. Why does it sound like you are landing on a metal roof? And it's like the sound is delayed... weird?
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
crazyjr
crazyjr's Avatar
09.17.2007, 12:29 AM
oh no, Squee's got the spaz back
jnev
jnev's Avatar
09.17.2007, 01:50 AM
Nice video's. I could also hear the ntiro's trying to be started, and some randomly shutting off.
squeeforever
09.17.2007, 05:06 PM
Larry, you can thank Brian for suggesting it.
phidailo
09.17.2007, 06:24 PM
glassdoc - the sound is actually from the crt & body hitting the ground so hard. I am thinking of changing the stock 50wt oil to 60 in front and 70 in rear.
Need some advice
phidailo
Need some advice - 09.25.2007, 09:13 PM
I didn't mention the reason I stopped filming the second video was due to a stripped center spur gear. I've had several runs at the track with no problems, but during this particular time I used a lot of braking to get around the corners. I use the motor brake so I'm thinking the gear stripped because of this?
I need some tips on racing around a track if you guys can help. What should my drag brake be set at?
Since I had to change out the kyosho gear I changed the stock diff oil from 10k to 30k. I'm leaving the front/rear at 5k for now, but I hear most use a thicker fluid in the front(thicker in front help get around corners better?). Also due to the hard landings I changed the rear shock oil to 70wt as well.
