video: 10sA123 Buggy with eagletree inserts
othello
HV basher
video: 10sA123 Buggy with eagletree inserts - 09.16.2007, 08:28 PM
So finally this weekend i found some time and made a video of my brushless buggy. In order to make this video more interesting for everyone i synced it with the eagletree data. 1580 Watt max on this run.
Chassis: Crono S6SL
Motor: Neu 1512 2Y
ESC: Jazz 55-10-32
Batts: 10s1p A123 (33v, 2300mAh)
Weight: 8.82lbs
Download video here. (70MB, runtime: 6m06s, windows Media 9)
this a still from the video
enjoy
09.16.2007, 10:05 PM
now that's a video! I love that you showed all the run data, too bad you don't have a bigger area to bash
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
09.16.2007, 10:22 PM
Nice the eagle tree data is impressive.
jnev
jnev's Avatar
09.17.2007, 12:07 AM
I really enjoyed viewing the data as you drove. Really added to the video. If you only had a bigger bash spot... that would be ideal. Great video none-the-less.
Finnster
KillaHurtz
Finnster's Avatar
09.17.2007, 12:36 AM
That's awesome w/ the ET
Makes me excited for my in-process setup of a 2Y on 10S A123s as well. What was the max current draw? Look like it stayed under 45A for the most part. The temp never budged either.
aqwut
Brushless Heavy Weight....
aqwut's Avatar
09.17.2007, 12:48 AM
awesome video dude..!!! I love the data...
Wow, I'm surprise it never drew more than 60 Amps... Cool... Must be because of the Higher voltage....
were the batteries hot after the run?
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
othello
HV basher
09.17.2007, 05:42 AM
Thanks for the positive feedback.
@_paralyzed_ and jnev
This was the first time i drove in this area. As i live in the city, it's not so easy to find some space to bash especialy on a beautiful sunday afternoon. This was my second battery pack. I also shot some video on a big open concrete space with my first battery pack but forgot to hook up the mic ;-( That's why i choose this part of the video.
Usually i drive in an other spot during the week. On weekends this area is filled with familys enjoying their bbqs. So no way to drive there.
@Finnster
The highest Amp draw was 60A. I had 7 peaks above 50A. The rest stayed below 45A. Motor temperature was no issue at all. That is the beauty of a high volt system when setup right. Outside temperature was around 20 C (68 F). As i have the non finned Neu i use two small fans above the motor, so that temperatures remain safe during summer time. The highest recorded motor temperature with 30 C (90 F) ambient temperature was 50 C (122 F). Without fans temperature reached once 70 C (158 F). That is when i decided to use some fans. With 10s A123 the motor spins up to 45000rpm and thus can heat up.
@Aqwut
That's right. With 30v, 40A already translates to 1200W. And you won't need much more in a buggy. The batteries are only warm to the touch (same for the ESC) after a 13 to 18 minute run, as my average Amp draw is around 10A. In this run for instance the average Amp draw was 9.78A or an average of 290 Watts.
lutach
lutach's Avatar
09.17.2007, 08:15 AM
Very impressive indeed. I thought about putting my Jazz controller in the buggy I have, but one stopped working after I had it in my truck with 10S A123. It was my fault as the Jazz performed well with a 2 pole motor, but with the 6 pole 600L it stopped and is giving me a warning light. I'll see what is wrong with it and hope it gets going again.
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
09.17.2007, 10:37 AM
That is so cool othello! Looks like it's a pretty powerful setup in the buggy, looks like it roughly 1200watts that it pulls.
How are you charging your pack? Balancing?
othello
HV basher
09.17.2007, 01:34 PM
@lutach
Jazz Esc are tough little controllers. I had 2 motor failures (overheating and front bearing broke) and in both cases (massive Amp peaks) the ESC survived. I even drowned one while being active accidently and the next day it worked flawlessly. My jazz 80 did fine with my 8 Pole inrunner with RPM peaks of 40000 which was above its rated max rpm of 150000rpm with 2 pole motors. So i wonder what happened with yours ... a 6 pole motor should run fine unless you would rev it above 50000rpm. Well of course Amp draw could have been an issue since it (jazz 55) is designed for 65A surge currents. But i would expect the motor to cogg when drawing more then 65A. Hope you can fix it.
@zeropointbug
Yep ... there is more then enough power. At least more then the tyres can handle
My peak was around 1560watt. i had 7 peaks higher then 50A. The rest was below 45A. So yep ... between 1200 and 1400 Watt.
I ordered a Hyperion EOS1210 which should be at my place this week. First i used a regulated laboratory power supply which is able to handle 36V and 20A. After 1 month it gave up on me. In between i use a Robbe infinity 2 charger which has no A123 program. So i terminate charging manually at 36V. Balancing is no big issue with those cells, as they kind of balance themselves when charging. Safe terminating voltage is between 3.6v and 4.2v so i don't mind too much about balancing.
zeropointbug
Z-Pinch racer
09.17.2007, 02:15 PM
1500 watts peak, that's good, I am getting over 1500 watts from a 7s1p pack, which I was surprised!
Too bad about your regulated power supply... I am using a BK Precision programmable PS unit, very good quality, excellent price too!
Name:	DSC06093 (Small).JPG
lutach
lutach's Avatar
09.17.2007, 03:26 PM
I hope Mike can have the PowerJazz with the Jazz car software. I will problably send all my Kontroniks to see if they need software update and a few to get fixed.
09.17.2007, 03:32 PM
Thats a neat video, kinda like watching F1 racing on tv with the telemetry data being flashed up as the car flies along; only F1 is boring, but that buggy was screaming.
zeropointbug
Z-Pinch racer
09.17.2007, 03:56 PM
I agree, F1 racing is pretty boring.... so little variables, too high of precision, it just makes for a lame experience.
09.17.2007, 04:10 PM
Unless they crash- F1 cars seem to explode rather incredibly, being made of so much CF, or the engines let go and turn the car into a 200mph fireball. So long as no-one gets hurt, it makes for exciting viewing.... **yes, Im evil**
