need help with Spektrum rx problem
Cartwheels
need help with Spektrum rx problem - 09.25.2007, 11:09 PM
On the plug where the ESC plugs into the receiver. If I push on the plug everything works correctly. After I hit a few bumps it stops working correctly. It comes down to, it's either a problem with the rx or with the plug. Where should I go from here? Should I just replace the rx? By the way is a 2ch sr3000.
