MM is way too hot! Why?
Xtremespeed
MM is way too hot! Why? - 09.29.2007, 10:39 AM
I just got my Neu 1512 1.5d/f this week. Running it on 4s2p A123, 14/46 in a hyper8 pro. The new motor is making a lot of power, and staying very cool. Hasn't been over 110 yet. After running no more than 2 minutes around the living room I heard my MM reboot. Checked the temp and it was 271 It was getting very hot with my Feigao, and I was hoping it was the motor, as the Feigao was also running very hot (210). The Neu is running cool though, so now I'm a little stumped. Obviously I'm not running the car too hard in my living room. What am I missing? Is my MM done?
glassdoctor
TEAM FUSION
glassdoctor's Avatar
09.29.2007, 10:46 AM
You running a ubec ?
Even without one I can't see how it should thermal in 2 minutes in the living room...
Unless it is cogging a lot... that makes it very hot very fast.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
Serum
Serum's Avatar
09.29.2007, 11:04 AM
some kind of binding in the drivetrain perhaps?
Xtremespeed
09.29.2007, 11:16 AM
I'm running a ubec, and removed the red wire from the MM. I double checked everything when I put the motor on and everything is free.
glassdoctor
TEAM FUSION
09.29.2007, 11:56 AM
Does it ever cog on startup? If it cogs bad even once and you pull much throttle, that can get it hot.
Try running it outside where it can run free and see what happens.
EDIT: ok.. I see you have the 1.5d not the 1.5y.... (please list the kv)
That may be the problem. You need to gear it down to about 10/46. 3200kv is a very hot motor so you are overgeared pretty bad right now for anything but speed runs.
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
MetalMan
MetalMan's Avatar
09.29.2007, 12:05 PM
I too think you are geared too high. I'm running similar gearing on my Hyper 8 Pro, but with the 2.5D/F and 4s Lipo, and with the MM. My MM has yet to thermal with this setup on a track, and there aren't any fans.
Xtremespeed
09.29.2007, 08:10 PM
Would the motor not run hot if it was overgeared that bad? I built this car for bashing and don't really have much interest in gearing way down as I don't have to drive real technical like on a track. I actually have some larger pinions I would like to try, but I think several people have run the 1.5d with 13-14/46 and had good results. I'm more into the wow factor I guess. Anyways, I've tried running it outside, and it's the same, just thought I would try some short bursts in the house to see what happened. I understand speed runs will heat everything up with my larger pinions, but could I get away with the 14/46 with another controller maybe?
glassdoctor
TEAM FUSION
09.29.2007, 11:53 PM
IMO nothing in the price range of the MM can hang with it... you have to look at the @$300 controllers to get much better as far as what it can handle.
The motor would eventually run hot too... but the esc will be the first to run hot when overgeared (typically)
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
Xtremespeed
09.30.2007, 11:11 AM
Just a quick update. Changed my pinion to a 13t this morning and went outside. My Neu was at 112 after about 10min pretty hard running and the MM about 190. I can't hardly tell the difference in top speed between the 2. Cogging is non-existant except for if I try to go full throttle from a dead stop. I had ordered a couple fans already, and they should be here tomorrow. This may be ok once I drill the case and get the fans on there. At least I think it will get me by until a better esc comes along. Thanks everyone for the help.
glassdoctor
TEAM FUSION
09.30.2007, 02:55 PM
Now try a 12t pinion... ;)
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
lxmuff
lxmuff's Avatar
09.30.2007, 04:16 PM
As mentioned before, try 12T next. You have lots of motor left.
Happywing
10.01.2007, 10:35 AM
You'll be able to smoke any nitro with the 12T. If you ever race, you'd want to go to a 10 or 11. The MM hole mod, a fan and the 12T will give you a long cool run.
miniGranis
10.01.2007, 02:49 PM
Originally Posted by Happywing View Post
..The MM hole mod, a fan and the 12T will give you a long cool run.
What mod is that ?
10.01.2007, 02:59 PM
Drilling several small holes in the plastic case to allow better cooling for the bottom FET layer and the BEC section.
miniGranis
10.01.2007, 03:06 PM
Aha thanks, anyone got any pics ?
