hey there...this maybe a silly question but i couldnt find the answer so here goes
i want to get the fastlane elec rustler kit (chassis bulks towers and arms) an the thing is this....it says that you can choose normal length arms rather than extended..but does this mean that the rears are normal and the fronts are extended so you can use the same offset wheels or are the front and back both stock dimensions..cause if they are completely stock i would rather widen the whole thing...
You can order the kit that has only the front extended and the rear regular length.(this is what I have). There is also the 1" extended chassis available.
