noob Shimming after bearing replacement
miniGranis
noob Shimming after bearing replacement - 10.07.2007, 04:04 PM
Hi !
Need to replace my axelbearings on my Revo 3.3
I tried one side but I can pull the axel in/out quite alot after I put in the new bearings is installed.
Am I correct in assuming that I need to put some shims in between the axelpin and outerbearing/axelcarrier ?
miniGranis
10.09.2007, 02:51 PM
Really no one has any ideas ?
To make it a bit more clear, after the bearing replacement I can push/pull the wheel in and out quite abit, and the axel (in where I put the wheel nut on) is moving so it not just that I havent tighten the wheel nut.
Any ideas at all if shimming is needed or if this is "another" problem ?
JThiessen
JThiessen's Avatar
10.09.2007, 03:03 PM
when you actually mount the tire/wheel on it and tighten it up, 99% of the play should be gone. When its just sitting on the bench without the wheel, that play is normal
miniGranis
10.09.2007, 03:36 PM
Thanks I will make another try to mount the wheel and check the play again.
