Lehner issues.
Hakan_J
Lehner issues. - 10.09.2007, 05:30 AM
Hi all,
I have been searhing the forums for a couple of problems Im having but without luck :(
This has probably been discussed before but I just cant find any info
I have two problems with my Lehner right now:
* My pinions keeps getting loose no matter how hard I tighten the screw
- Has anyone tried making a flat "spot" on the shaft on a lehner with only 4mm shaft? Has anyone tried it on any other motors?
* I have managed to strip the thread on two of the holes in my Lehner.
- Anyone have any advice on how to fix this or advice on how to avoid this from happening to my other holes?
Thanks in advance!
Br,
Håkan J
chilledoutuk
10.09.2007, 05:44 AM
well i have seen some people use threadlock on the grub screw on pinions.
about the hole threads i would make sure that your machine screws fit snugly into the lehners thread.
I know some m3 machine screws are not a close fit.
Also how deep are your machine screws going into the motor when you mount?
Hakan_J
10.09.2007, 06:52 AM
Im going to test using threadlock but I fear I might have a problem when I want to change pinion?
I have measured my screws and cut them so that they should be as long as possible so I dont think thats an issue. I will check the fit on my m3 screws more closely!
Patrick
Patrick's Avatar
10.09.2007, 07:43 AM
I dremel a flat spot on my motor shafts, and I think most other people do as well.
dadnjesse
10.09.2007, 08:13 AM
I think you should always use thread lock on the set screw!, I use the red and never have a problem. Then to take it off you can heat the set screw with a soldering iron, or I use a small butane torch.
Dafni
Dafni's Avatar
10.09.2007, 08:27 AM
Ask Mike for his Lehner frontbell cover. You'll never have to worry about stripped holes on your Lehners ever again.
Daf
Hakan_J
10.09.2007, 08:32 AM
Daf
That sounds great! Do you have any pictures?
jhautz
jhautz's Avatar
10.09.2007, 08:43 AM
It looks like this.
Works like a charm.
to make it...
or break it...
Silent...But Deadly
Hakan_J
10.09.2007, 08:49 AM
Wow that looks great!
I will definitely ask Mike for a couple of those!
Finnster
KillaHurtz
Finnster's Avatar
10.09.2007, 10:22 AM
You def need a flatspot on the shaft. 5 min w/ the dremmel & its done. I (sometimes) use the blue locktite and a good hex driver and haven't had a setscrew come loose since IDK when.
Hakan_J
10.09.2007, 10:26 AM
But is it safe even with a 4mm shaft? I dont want it to break
10.09.2007, 10:58 AM
The flat spot needs to be just big enough to give something for the screw to work on. Also, blue lock-tite seems to be strong enough from what I've seen while making it relatively easy to remove.
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
10.09.2007, 01:03 PM
I agree, only use blue lock-tite... the red stuff will ruin your live!
I would also get that Lehner front bell cover as well, that should fix your problem.
Cartwheels
10.09.2007, 03:06 PM
I have also had luck flattening the bottom of the set screw. More contact area I guess. That combined with blue lock-tite.
coolrunnings
10.09.2007, 07:44 PM
Any motor without the flat spot on the shaft must get one first thing. O and that front bell cover is sweet, I will call mike for one even though I dont need it.
