Radio Glitches & Brushless -
10.27.2007, 02:03 PM
Ive been having major glitching issues with my all aluminum Pede since day 1. I have the MM 5700 with Maxamps 6000 3s packs. Im using a Jr XS3 radio.
I can only get about 100ft away, then I basically lose signal and the truck takes off! The funny thing is, the same receiver from the pede will work perfect in my Brushless T4.
Ive tried everything under the sun to correct the problems, even Castles reccomendations. You name it I probably tried it. Ive concluded that the all aluminum construction has something to do with increasing the interference.
So, my questions are 1. What radios are you running, and 2. What kind of range are you getting?
Thanks for any help.
