can anyone repair, caps, on MM esc -
10.31.2007, 02:28 PM
Well I bought a used mamba max esc and when I got it one of the caps looks like a dog chewed on it and smoke comes from it.... So I am needing it repaired and better caps added for higher voltage is there anyone here on the board that can do this for me? that has a good reputation
If you can open the case & possess a good iron, it is simple enough to replace the caps with suitable ones yourself; but only if you are confident- dont think about it if you are even the slightest unsure. Castle will fix that for the standard fee I would have thought- $25 isnt it?
GriffinRU could perform his stage 1mod on it for about $50 or so... (better caps of the same voltage rating to improve cooling and reduce voltage sagging under load).
Based on personal experience, Ii you are going to run ANY brushless motor on a mm (except a tiny one!) Griffinru's mods will make a huge improvement in startup and overall heat management. I ran a 7xl on a stock mm and a modded mm and the stock one had to have a fan to work and even then it got hotter than the modded mm did with out a fan. I ran the modded mm thru 2 packs back to back (at least 40mins) and it did not get over 140f. Well worth the $50 or so he charges. I currently have 2 mm that I sent him to mod and will run them both on 7xl motors in two new vehicles that I am converting.
