Right RPM AArms and MIP CVDs for my Maxx
marc993turbo
Right RPM AArms and MIP CVDs for my Maxx - 11.05.2007, 08:47 PM
Hallo together!
A i wrote yesterday, i am currently building a G-Maxx/Slipperential based eMaxx.
It is my third Maxx and the first one for which i will use rpm suspension parts. I definitely have no experience with rpm parts but i want to try them because they seem to be quite good and durable.
I want to order the _correct_ parts that will fit to my gmaxx chassis but i am not sure which to order because there are many different versions.
To make this question short:
Will the Rpm parts for the 3.3 T-Maxx fit to my g-maxx chassis and unlimited bulkheads?
http://www3.towerhobbies.com/cgi-bin...?&I=LXMZT3&P=7
Do i correctly assume that i have to use the following axle carriers?
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXEXG4
Or will only the following fit:
http://www.rpmrcproducts.com/product...o.htm#carriers
Seems that i am a little bit too stupid to just order some plastic rpm parts. I only used alu parts till now...
It would be nice if you could help me out, i don´t want to order the parts two times.
Last question: If i use the t-maxx 3.3 parts i will have to use the following mip cvds, correct?
http://www3.towerhobbies.com/cgi-bin...&I=LXNTT8&P=ML
So will all the appropriate T-Maxx 3.3 parts (Mip CVDs, RPM Axle Carrier, RPM A-Arms) fit to my Unlimited Bulkheads?
Some help would be appreciated.
Thanks,
Marc.
