Revo center dogbone
david lamontagn
Revo center dogbone - 11.06.2007, 04:08 PM
Is somebody make a kit of center dogbone for the revo to replace the stock plastic slider?
Because Mike have the new V2 diff case with an unmodified pinion gear and we need of special center drive shaft like the savage, LST, MGT or any other "normal" monster truck
Plus, i need a 6mm diff outdrive for the tranny side and a 8mm for the new unmodified pinion on the diff side.
Another headache...
riceman
RC-Monster Gold
riceman's Avatar
11.06.2007, 05:00 PM
Not sure if this will work for you but have you seen Vantage Racing's center shafts?
david lamontagn
11.06.2007, 05:46 PM
I don't know if this dogbone are 6 or 8mm, but if it's 6mm, i don't think that this work with the 8mm diff outdrive that Mike give with the V2 diff.
